02-04-2010, 08:20 AM | #16 | |
A think a replacement vehicle is on the short list. I haven't been back over to try anymore things.
02-04-2010, 09:43 AM | #17 | ||
@300,000 I would do a complete "old-time" diagnostic: check compression and *timing chain* (if not a 4 cylinder) use an ohm meter on the wires, clean-up check coil packs/distributor (if a distributor check the advance mechanisms, both mechanical and vacuum, check vacuum advance for vacuum supply) look/check the EGR system, including function and gasket. The thing has to be reasonably healthy before you go sensor hunting. |
02-04-2010, 11:04 AM | #18 |
I am thinking that the compression is probably getting low. It is a 4.0 v6. I am not sure if has a distributor or not.
Compression test? Those plugs are not easy to find. Can't I just pushed it off a cliff. Allen
02-05-2010, 07:44 AM | #19 |
if you should decide to push it off a cliff make sure there isnt a forum member riding at the bottom. 8O
my help may not be the best but it is free+-Seek ye first the kingdom of GOD |
02-05-2010, 08:22 AM | #20 |
I believe it is soon destined for the craigslist. About the only thing it has going is a straight body.
02-06-2010, 05:01 PM | #21 |
Well I installed a used MAF sensor and the check engine light went out. Seems to be running pretty good too.
Also put in a used blower fan so she will have heat. Will see if we made and improvement. I was getting all set too run the diagnostics. Allen
Thread Tools | |
