What the heck is that rattle???
Any time I ride my GY-5 in every gear something rattles when it revs. It sounds like it is under the gas tank. Can't find it. Skid plate is not loose. It is very loud and very annoying. :evil:
2007 United Motors DTF-200, 2007 Ninja 650R 2007 Suzuki Boulevard M50 |
Do you have one of those big black metal plates that your license plate sits on?
My license plate was rattling in every gear as the rpm's rose. It sounded like something around the engine was vibrating. I finally glued 2 rubber hose washers under the bottom portion of the license plate. Rattle gone. Also you might check the heat shields on the exhaust to make sure they aren't loose. |
Built my own licence plate bracket, took that monster one off, no rattle from that any more, also check your keys, if you have more than just the bike key on your key chain, rubber band them together ie. house keys, shop keys...
on one of owr vivas the muffler rattels, some day I may cut it apart and fix it. or not.
Love from the Arizona High Desert |
#5 | |
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
No worries. MS Randi has a press in her shop. She is a tool freak.
Ride hard and have FUN!!! |
I had already fixed the license plate rattle. It wasn't that. It is definitely coming from up under the gas tank somewhere. All my heat shields are tight and so is my skid plate. If it is in the exhaust, it is inside it somewhere, because it seems tight, too. AAAARRRRRGGHHHH!!!
Being a push rod engine a little noise is normal, have you taken the tank off and checked underneath?
Yes, I took the tank off and couldn't see anything loose. I don't think it is engine noise. It sounds like a vibration noise. It only happens through a certain rpm range. If it gets up closer to 6k rpm, it doesn't do it as bad.
You might check your horn. I had a rattle that I couldn't find, then one day my horn was dangling by the wire. Yanked it off and ever since - no rattle! Guess I better mount it back up for inspection before the reg is due.
Did you ever find the rattle?
Hi there,
I have checked and double checked every nut and bolt on this bike, and even installed rubber washers in a number of areas. I still have the rattle. I have tried to isolate the vibration without any luck. My next step is top remove the air fins in the front, and the tank skin plastics. I have about 300 miles on my GY now, and this is the last thing to be buttoned up. Any info appreciated. Thanks |
Welcome Ayjay,
I've rippped my bike down to bare and reassembled it and it still has a rattle or 2, not all the time...I think it's the nature of these bikes and that's what makes them fun, wish I could give you an answer but you'll find it and post for all of us to see...China bikes rule...
06 Lifan 200 GY-5 |
