Old 03-05-2025, 12:17 PM   #1
BkrMike   BkrMike is offline
AGM battery for SSR xf250?
Does anyone know if there is an AGM or lead acid battery available for the SSR xf250? I just picked up a 2023 leftover and I do not want to use the Lithium battery it came with. I searched this forum but did not find any information related to the swap. I also checked the web but all of the cross reference batteries were also Lithium. Some help would sure be appreciated.
Old 03-05-2025, 10:39 PM   #2
Based on the manual you can find here;
https://www.ssrmotorsports.com/store/owners_manual.php
You need a 9ah battery. You'll have to measure your battery box to find what will fit. Also check to be sure that the battery you chose has the terminals on the correct side.
Edit - in another post you said your bike is a left over 2023. SSR says on their website that 2021 is the last year of the XF250. Do you have the SR250S or is SSR wrong about the years? The reason I bring it up is the SR250S manual says that it requires only a 6ah battery. That would make sense, I guess, if it was lithium.
New edit - I looked on Facebook and saw that the dealer is selling the XF250 so the 9ah recommendation is correct.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 03-06-2025, 05:32 PM   #3
Thank you for the advice.
Search this Thread:
Advanced Search
Display Modes
