Roketa Headlight Problems/ Headlight Bulb Source
Anyone know a good source for Roketa parts, specifically headlight bulbs?
I have a two bulb system. A small low beam bulb and a large 35w high beam bulb. My high beam bulb quit although it doesn't look to have burned out I want to get a new one to try before I go tearing into things. My bike is 2 years old with 1000 miles on it. Anyone else had any headlight problems? |
light bulbs
I order my 12 volt 35 watt bulbs from denniskirk.com. The small bulb you can get from O'reillys auto parts or your local automotive store. So far I havent found the big bulb at an auto parts store. I have misplaced my paper that has the numbers but they are EIKO brand name that replace them.
found it
The big headlight bulb is an EIKO part # 22-304
Just wanted to add that that little tiny bulb is NOT the low beam. It is a parking light.. The bigger bulb hsa two elements in it... both high and low... He is right thou you can get that small bulb at an auto parts place..
Thanks for the link for the big bulb.. I need to get one myself.... 2 years and 3200 miles.. it wont be long till it goes. Ken |
Thanks!
By the way, I am a she. The small light also works for the taillight/license plate light.
bulb
FYI, My low beam was out also and the bulb looked good. I checked the connector on the wire and one of the pins was pushed out when the plugged it together. Pushed it back in and was good to go. BTW, I ordered the bulb from Denniskirk after my stock one finally did burn out.
http://www.denniskirk.com/jsp/produc...d=41101&mmyId= The new one was an exact fit for my Lifan.
Bone stock 2007 Lifan GY-5 |
