10-22-2024, 05:02 PM | #16 |
Consider yourself lucky that all you got was some abrasions on your bags. If those would have gotten into your chain or wheel.......be careful with bags and things that dangle. That could have been much, much worse.
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
10-22-2024, 07:55 PM | #17 |
It was tied tight when i left work, sometimes things just happen, its better not to dwell on the little things like that, luck has nothing to do with it if god decided that's how I'm gonna go, well that's just how I go. I came up with a solution and learned from it that's all that matters.
11-06-2024, 11:18 AM | #20 |
got a nail in my back tire leaving work last night so I ordered a kenda heavy duty tube, and since Im already gonna be working right there I went ahead and bought a D.I.D chain and a set of 17/45 sprockets.
11-13-2024, 09:31 AM | #21 |
Went to harbor freight and bought a stand to work on the bike this weekend. My rear sprocket and chain made it in, still no sign of the tube amazon shows delivery Saturday. Went ahead and ordered an extra for the front and rear so if it happens again I can fix it right away this not being able to ride to work is for the birds!
11-13-2024, 12:42 PM | #22 |
Got any links to the luggage rack and chain guards? I don't have a luggage rack currently. I just bungee stuff down between the rear grab bars. I don't like the floppy plastic chain guard either....
11-13-2024, 01:18 PM | #23 | |
https://www.amazon.com/stores/BAOUFF...CCZBBR2HBTPZAC I have the csc tubular luggage rack that I took off, you can have for the shipping cost if you wanted it. |
11-14-2024, 04:38 PM | #24 |
Awesome! Thank you, Hebbe. That's the 1st I"ve seen an Amazon store with a collection of Hawk 250 parts.
11-16-2024, 06:10 PM | #25 |
Took the tire and tube up to the local mom and pop Harley shop (shout out jims cycle shop!) I work with through my job and they swapped the tube for free! I also grabbed some amsoil 10-40 to try on my next oil change. After I took the rear sprocket off of the rim I realized that my DLX hawk came with a 45 tooth stock in the rear, the front stock was a 16 I went ahead and put the 17 tooth on the front I can always swap back if I don't like it. Still have to install the new chain and then I'll be back on the road! 15 years working on diesel trucks, I realized I should have been a motorcycle mechanic everything is way lighter!
12-05-2024, 01:33 PM | #26 |
a few days after I changed the sprockets and chain I had one of the little green chinesium sprocket studs start coming loose every time i rode the bike. I had ordered the Honda 90128-ke2-940 but didn't want to wait for them to get in and everything was good and tight at first. I swapped them out and everything is good to go.
