#61 |
I ran out of cut off wheels for my dremel tool but I have these pliers that managed to get the OEM carb screws out without much fuss even with the red thread lock on the bolts. Engineer PZ-57 Japanese pliers($16 on Amazon, a great alternative if you don't have a dremel tool or don't want to spend the money for this one job). You will need M4-.70x20mm screws to replace the OEM headless bolts.
I could only fit one .5mm shim under the needle and still have the white plastic needle retainer clip into the slide piston. ![]() |
#62 |
Lowered-Kickstand fix
I posted the 5/8" new lower mounting hole on the rear shock (post #59), which drops about 1.75" and if you drop the front forks about a half inch, you get a solid 2" lowering. I also compressed the preload by about 175 pounds (~ half inch @ 350 pounds per inch). This is a NICE way to stiffen and lower the bike moderately.
BUT, the kickstand is too long now. Aussie mentioned that the kickstand had nice thick walls, so I decided that my weak welding skills could be successfully brought to bear ![]() I took a ~1.25" section out, below the lower spring mounting post: I set it up pinning it vertically to a red landscaping cinderblock and ground off a section to pin the grounding clamp: A strip of masking tape was good enough to hold it for the first tack weld, then pulled the tape off and finished it off: Lovely weld, eh ![]() In my defense, most of that is slag. It was pretty good underneath the mess ![]() I filed off the crap and gave it a flat black finish. Done. The bike leans over nicely. You can even park it with the kickstand uphill now. Plenty strong enough. This worked out great.
-NOS 2020 KTM 250SX (2-stroke motocross) Last edited by Thumper; 07-04-2024 at 12:25 PM. |
#65 |
No, it's 31mm. I bought a 31mm socket and it fits perfectly compared to the loose fit of a 32mm. Nut 31.22mm 31mm socket 31.4mm 32mm socket 32.2mm (ISO/DIN standard: 32.08 - 32.48mm) If someone uses a 32mm with an impact to loosen it they are going to deform the nut. |
#66 |
32mm works. A 1-1/4" socket will also work. I use a breaker bar.
-NOS 2020 KTM 250SX (2-stroke motocross) Last edited by Thumper; 06-20-2024 at 11:40 AM. |
#67 | |
If a 32mm fits, also great, I would use that. If some standard size fits better than either of them, I would use that. My point is. Who cares? Use whatever fits the tightest or works. This is like arguing about who got more milk in their glass.
#68 |
I'm glad the 31mm socket works for you. My 32 works, and I have a 1-1/4" backup that works too. It's just a couple of turns to loosen, tightens easy to, and I like using a breaker bar to make it easy. It's like 55-60 foot pounds. No need to use an impact driver. I don't need to buy a new socket.
#69 |
I used an adjustable wrench because I couldn't find a suitable socket. I think I have a 11/4" socket so if I can find it easily I'll try it next time. Maybe buy the right socket some day.
22 Templar 250 |
#70 |
I'd appreciate it if like a half a dozen or so posts at the tail of this otherwise very helpful resource thread were deleted.
And then this one too. For the record, until a few posts back I never knew or cared what size the axle nut was. I just loosened and tightened it with whatever it was I had that fit. An adjustable wrench would work. I see it as a non-issue.
2023 Templar 250 X |
#71 |
you are so right GypyR. a pair of good pliers wood work.
#72 |
I just bought the last one of these gear position sensors for the Templar X 250, and here's the link in case someone else wants one when they restock: ebay.com/itm/225647471555 (copy-paste to your browser's address bar)
It's sold by XPro. Once I install it, I'll edit this post to confirm that it fits, and at least didn't make the problem any worse (missing indicator for 1st gear).
Templar X 250: 14t / 42t, Nibbi PE30 |
