X-PRO Hawk DLX 250 EFI Fuel Injection 250
We ordered a 2024 X-PRO Hawk DLX 250 EFI Fuel Injection 250 and I am aware of the poor quality inner tubes. I'd like to buy front and rear aftermarket to have on hand. Could someone please send me a link to a website that has them both. I also think we will go with the 17/45 sprocket combination, so a link to that would be ideal as well. I have been looking on csc website but they listed several options. Thank you in advance.
I have been able to source parts mostly from Amazon for my 2022 RPS Hawk DLX EFI. I do not know what may be different between the model years, if anything at all.
I bought my Hawk used, so many mods were done already. I have sourced the following parts from Amazon; -kickstart lever (previous owner removed and lost) -47t rear sprocket -hydraulic brake light switch fo rear brakes -billet foot pegs + springs -handlebar grips -sparkplug -fuel filter -gasket for fuel tank lid
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
Be careful with CSC TT250 parts. Many are the same or interchangeable with Hawk parts, but not all.
Hey guys picked up a 22 fuel injected hawk dlx and noticed the forks are much thicker . They appear to have 49mm fork tubes what other bikes have 49mm forks that I may slide a new front end on I have seen someone use xr200 shocks for the regular hawks with the smaller forks but the dlx has more options with the triple clamps accepting the bigger forks. Drz I believe has 49 mm and rmz. The point is I’m planning on doing a super moto setup and the short forks make the hawk look awful. Fun bike tho for what it is would be cooler if u can cruise highway without feeling like your gonna blow the motor up lol I may try to swap a old xr250l motor in it one day those boast 30 hp and top out at 78mph and have a 6th gear but this fuel injected one is a very pleasant experience not having to tune your carb often
Which fuel filter did you use? Like, what size should I look for to replace the stock one with aftermarket?
#7 | |
https://xprousa.com/ Parts: https://xprousa.com/collections/featured-parts Go to Amazon and do a search. You probably need to know sizes and stuff. For that, you can look at your tire, you can look in the manual or you can check out Megadan's kickass thread on our bikes: https://www.chinariders.net/showthread.php?t=20331 That thread is pinned to the top of the Dual Sport/Enduro section of the forum. Before you post asking for links to shit, please do a little searching on your own. Thanks in advance.
#8 | |
NEW DAFU In-Line Fuel Filter 15... https://www.amazon.com/dp/B09ZQSZD5Y...p_mob_ap_share The 5/16"/8mm is going to be the correct size for the Hawk DLX EFI. The in-line filter is under the front edge of seat/rear edge of fuel tank in front of the air box. There is also a mesh screen type filter inside the tank. I have not replaced that yet. The attached picture shows the fuel lines from the tank-to filter-to throttle body with the new filter(silver) next to original(black).
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) Last edited by Do©Hawk; 07-31-2024 at 04:21 PM. Reason: More info |
i just purchased a 2024 rps hawk 250 dlx and it came with 17t and 45t sprockets i weigh 180 lbs and am getting 75mph all stock and have got 78mph down hill
speedo indicated, or GPS indicated?
Dave Bikes I've owned: Suzuki GS450T, Yamaha XS500, Honda V45 Sabre, Kawasaki Vulcan 1500 Classic (2), Suzuki VX800, Kawasaki Ninja 650, Triumph TT600, Honda Superhawk, Kawasaki Concours 1000 (3, including a sidecar rig), Buell XB9R, Kawasaki Nomad 1500, Concours 14, Honda Goldwing (2), Housen Hawk, Suzuki Intruder 1400, Kawasaki KLR650, Victory V92TC. |
inner tubes. |
