#61 |
Now I'm looking to purchase a service manual for the Linhai 260/300 4x4 atv.I have a couple already downloaded & saved on my computer but I want a paper back version.I just don't know if my printer could print out 360 pages plus whether I got the ink to do that.
#62 |
I've been going around the atv trying to find all the zerk grease fittings and applying some grease to them.I think I have found them all & am now wondering about the front hub carrier bearings.Their like the old cars & tractors ect & their not a sealed bearing.
#64 |
I would drill and tap it to install a grease zerk.
#65 |
That's the 2wd version above & I don't know if that is a threaded hole for the zerk fitting or not.The 4wd doesn't have that & has the splined shaft running through it.
#66 |
#67 |
I think they skimped on the grease in the fittings,some I don't think they put any grease in & that's why I'm worried about the front axle bearings.
#68 |
I'll have to take the wheel off,cotter pin & nut just to see what kind of grease is in there.There's a grease fitting on the steering shaft,I had to take the front cover off to get to it & they must have never put any grease in it,so much easier to steer after putting grease in the steering bushing.
#69 |
As long as the zerk doesn't interfere with the bearings or shaft, I wouldn't think you would have any issues with installing one.
#70 |
Parts catalog.I'm trying,one picture is to big & the other is so small you can't hardly see it.I'll just have to take the hub carrier off to see.
#71 |
dugndeep
Can you eShare the Service manual with Parts Catalog for the Vitacci Terminator aka Linhai LH300? Needing to get a full replacement Transmission, so need the service manual parts numbers - another ATV rear ended me and the transmission is now stuck in HI gear and won't slip into Neutral or Reverse any longer. Then will need to research where I can buy the replacement transmission. |
#72 |
ndlangub good luck finding parts for this 4 wheeler,was thinking of buying one. Until i started looking for parts,no good.
#73 |
Parts are available from the dealer and also can be found on AliExpress. Linhai is the actual manufacturer.
