05-09-2024, 06:49 AM | #1 |
Where can I get shark 250 front brake caliper
So I have this 17" 19" Chinese enduro that has a single cylinder front brake that looks like the posted pictures and I'm trying to find a replacement. It's a shark 250 enduro. Where can I get one that will work?
05-09-2024, 06:57 AM | #2 |
05-09-2024, 08:02 AM | #3 |
05-09-2024, 09:36 AM | #4 | |
05-09-2024, 01:07 PM | #5 | |
Is it this one if taken off the mount? Because the bolt spacing is not 2.4ish inches on this one. |
05-10-2024, 01:37 AM | #6 |
I can't even find that style for the front. I almost wonder if it wouldn't be easier to change out for a 2 piston caliper like the Hawk and other standard fork bikes use. The mounts on the fork lower may be the same. I could measure the spacing of mine to see if it is.
05-11-2024, 11:18 AM | #7 | |
Can I use a two piston one for this disc? Is it compatible? Which one should I use? I'm a bit confused really. |
05-14-2024, 02:50 PM | #8 |
Any idea if the hawk front brakes would mount?
05-16-2024, 01:20 AM | #9 |
No clue, but the bolt spacing on the forks of the Hawk is 2.4 inches/61mm (roughly) from center to center.
