Old 10-17-2023, 06:33 PM   #1
Zapkin   Zapkin is offline
Zapkin's Avatar
chain adjuster upgrade?
is there something like this out there that would fit the hawk?
https://www.amazon.com/dp/B0BJNKW164/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B0BJNKW164&pd_r d_w=fSJTW&content-id=amzn1.sym.f734d1a2-0bf9-4a26-ad34-2e1b969a5a75&pf_rd_p=f734d1a2-0bf9-4a26-ad34-2e1b969a5a75&pf_rd_r=68HCZBV9MS6YM7C29A3W&pd_rd_wg =rhUHP&pd_rd_r=ed93b5bb-8649-4537-aa4e-1ccede2baa44&s=automotive&sp_csd=d2lkZ2V0TmFtZT1zc F9kZXRhaWw
2022 Hawk 250
Old 05-10-2024, 03:16 PM   #2
BADHIGEEN   BADHIGEEN is offline
BADHIGEEN's Avatar
yea the hawks adjusters suck pretty bad. did you ever find anything?
Old 05-12-2024, 02:33 PM   #3
Zapkin's Avatar
no i just check them constantly. i think though nearly identical, the ones for the tt250 are stronger. but I am not 100% sure on that.
2022 Hawk 250
Old 05-12-2024, 02:37 PM   #4
Zapkin's Avatar
https://cscmotorcycles.com/stock-rep...dy/rear-wheel/
you want item 8..two of them.
2022 Hawk 250
Old 05-12-2024, 04:12 PM   #5
I don't really like the fact that the rear swingarm is basically just square tubing, but I don't see anything wrong with the adjusters. I guess they could be just a hair wider, because people tend to tighten the axle nut a little tight, pulling the outside wall of the swingarm in a little.
Old 05-13-2024, 06:05 AM   #6
superjocko   superjocko is offline
Here's a thread on what I did to my TT250: https://chinariders.net/showthread.php?t=33914 (scroll down to posts #6 and #7) I believe the Hawk to be very similar.
The threaded adjusters themselves are still the stock ones that came on my bike. The stock adjusters from CSC are decent enough and, while they slide freely inside the box section tubing of the swingarm, they don't have excessive clearance that causes the box section of the swingarm to collapse significantly when properly tightening the rear axle.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come.
Old 05-13-2024, 10:08 PM   #7
Tons of bikes, including a lot of big name brands, use swing arms that are basically just tubing. Usually just a bit better quality, or thicker, or both.
Old 05-13-2024, 10:10 PM   #8
The CSC Unit's aren't any stronger really, but like with most parts on the CSC bikes, the quality is definitely a bit better. Great factory replacement/minor upgrade option.
Search this Thread:
Advanced Search
Display Modes
