03-21-2024, 10:15 PM | #1 |
Hello
I'm Edwards bought the hawk 250 dlx efi about 2 weeks ago and still haven't ridden it because at 6009rpms the engine cuts out, gotta pop the clutch and feather the throttle to keep her running.
03-22-2024, 08:27 AM | #2 |
Welcome aboard! That doesn't sound normal. Check that the spark plug is securely set in place. If it has the cheap Torch spark plug, i would replace it with a good NGK plug.
03-22-2024, 11:50 PM | #3 |
Air leaks around the carburetor, slide cover or intake maybe.
03-25-2024, 07:20 PM | #4 |
Welcome, Edwards. Is your Hawk throwing any check engine codes?
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
