Motor oil went place
We poured .75 of a qt. Of oil in the top timing inspection hole that you remove with a flat tip screw driver on upper left side of motor. Oil came out somewhere. What should we do.
125 blazer
So far we just let it drip. Changed the oil and filled in the proper place and it will start. Wondering if we should do anything else.
You might have to remove that cover and clean it up. That means removing the rotor. The oil can be put in through the top of the head if you must (slow), but the oil usually goes in at the oil check port by the clutch cover.
On the other hand, it might still charge OK, and slowly drain out over time.
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 03-10-2024 at 04:21 PM. |
