#1636 | |
Although mufflers and catalytic converters can help reduce the problem of spark emissions, they are not spark arresters. Catalytic converters also pose a special fire threat as they generate temperatures in excess of 2,000 °F that can ignite wildland vegetation."
Templar X 250 Vespa GTS 300 Vespa ET4 150 Triumph Legend TT 900 |
#1637 |
My catalytic converter started a grass fire underneath the bike last year when I fell over on the right side. I was able to drag it off the fire and put it out, but it easily could have gotten out of hand. Decatted headpipe with a spark arrestor in the muffler is definitely safer!
#1638 | |
#1640 |
Hey,
I broke the clutch perch the other day riding.. was lazy and didn't take off my mirrors for off-road and fell over onto the left side. Snapped the perch right off. Decided to buy new levers and perches ( and folding mirrors ) the choke lever doesn't fit on the new perch, and I would like to get rid of the choke cable anyways. I ordered a pull plunger type that fits right on the carb but how tight it is under there I doubt it will fit. Wondering what you people here have done in regards to the choke? For now I just have the choke cable zip tied to the bars out of the way. I can pull the internal cable by hand when I need it. |
#1641 |
Templar X with Fisch spark arrestor (kit 30) installed. It does tame the exhaust note a bit. This bike has less than 30 miles on it but I think it is pretty dialed carb/mixture wise
#1642 |
You sure can use like that, to will proably need another carb
#1643 |
Good to hear it tames the sound a bit.
#1644 | |
Nice!! Mine arrived today and I just installed it. Couldn't get it to seat in as far as you have yours, I think I'll likely cut the stinger off the back of the muffler soon so that I can reinstall it almost flush with the rear of the muffler can. |
#1645 |
My tailpipe was a little ovalized so I introduced it to a metal rod to make it more circular then convinced the spark arrestor to mate more closely with the pipe by persuading it with a very large rubber mallet.
#1648 | |
Prior to the hot start, it's probably not a setup anyone would care to replicate. Involves a fragile, adjustable, universal clutch lever, washers in plastic and metal, some SAE socket, an extra one of those cable adjuster nuts, and some self-adhesive tape (like for tennis racket handles) to wrap it together with the clutch cable and keep my creation hidden from the world. Describing it, well...now it seems a little silly.
Templar X 250: 14t / 42t, Nibbi PE30 |
#1649 | |
#1650 |
Spark Arrestor clarification question: I've been researching Spark Arrestors and was planning to buy the Fisch Moto Spark Arrestor that has been suggested by several others.
The bikes I have will be primarily driven off-road on my own property with occasional on-road use planned as well (later on anyway). I like the idea of protecting my property from any chance of fire, as my property is basically open field and some wooded pathways. I thought i'd add the arrestor as a precaution and then also be covered should I ever get a chance to take them to a National Park. However, The Amazon link has a legal disclaimer that states "Fisch Moto products are sold for off road use only and are intended be used on vehicles used solely as such. Installation and use of this product may be in direct violation of local laws and are therefore not to be used on public roads." Could I get in trouble or fined by having a Spark Arrestor installed and using the bike on a public road? The legal disclaimer was found here: https://www.amazon.com/FISCH-MOTO-Ar...082FVG2KH?th=1 |
