Old 12-10-2023, 03:35 PM   #1
woodsnwater   woodsnwater is offline
Rear sprocket question for Brozz Recon
I want to gear down for woods riding and am looking at the JTR269 50T sprocket. Will it fit my 2020 Bashan Brozz Recon 250? Probably need to replace the 4 mounting bolts while I'm at it.
Old 12-10-2023, 04:03 PM   #2
Bill Hilly   Bill Hilly is online now
The sprocket will work just fine, but it will not be slightly dished like the stock one on the Brozz. A 15 tooth front will gear you down, and is a lot easier to switch back and forth with the 17. The studs are these. I always but them, but see no reason to buy the nuts. You will also probably need a longer chain if you replace the 46 with a 50. If you still have the stock chain, they need replaced anyway .https://www.adeptpowersports.com/oem...-940-part.html
Old 12-10-2023, 04:32 PM   #3
Thanks Bill Hilly, maybe I will consider changing the front sprocket instead. Already changed the chain to an o-ring model. Pretty sure it's 130 links.
Search this Thread:
Advanced Search
Display Modes
