200 168 efi scooter fuel pump
My particular scooter is a vitacci force 200 efi but I'm sure most of the newer efi scooter use the same fuel pump assembly. Anyone found a non dealer source for these?
My pump works fine but fuel gauge not working so might have to replace the whole assembly. Also anyone have a wiring diagram? |
I've taken the unit out of my Clash to have a look. It's a very simple unit with only 4 wires if I recall correctly. 2 wires to the pump motor and 2 to the fuel level sending unit . Very easy to test on the bench with an ohm meter.
Did this work? Believe my Tank 200 is in need of a fuel pump.
I have a Clash 200 with 115 miles. It ran great till yesterday. When I turned the key didn't hear the fuel pump run and of course no start. Any thing I should try before replacing the pump?
