#76 |
Need a new battery for my KPX. The current one has been sitting since last year, other than a short ride a couple months ago. Multimeter said 2 volts, so it's now on a charger. But a brand upgrade would be nice. What's a good Li-ion make and model number?
#77 |
My modded KPX airbox cover. Twenty holes each 5/16" diameter gives an extra intake area of 3.06 sq in, very close to the same as one 2" diameter hole. Hopefully riding tmw, weather permitting. We'll see what the computer thinks of all the extra air. I have also been recharging the battery off the bike (which will reset the computer) and am installing a Battery Tender connector, so I can now easily just keep it charged up. I may also glue some screen door screening to the inside to keep out bugs.
#78 |
Cool let us know how it goes.
The Bearded Vagabond YouTube Channel |
#79 |
Battery won't charge up enough to crank, on the Battery Tender. Gets to 12v, but drops down to 11.5v as soon as I remove it from the charger. Won't crank.
![]() Edit: Rain all day tomorrow, starting at 9am.
#80 | |
![]() Charge the battery with the ground wire disconnected from the battery, then check the voltage on the battery after charging (with the ground still disconnected). It should be 13V or more. Then connect the ground post and see if the voltage drops. If it does, you have a device drawing current that is responsible for the problem. It is an easy test. All of this done without the key even in the ignition! ![]()
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 08-09-2023 at 07:59 AM. |
#81 |
Tom, if you have the stock battery, it might be a bad one like I had. My battery crapped out after about 3 months. Think the first batch of bikes had bad batteries. Venom had sent me a new battery and never had any issues since.
#82 | |
Ordering new battery off Amazon today. Is Mighty Max considered a good brand? They also sell 'em at Home Depot and Lowes, so that is a good sign at least. https://www.amazon.com/exec/obidos/A...ustomerReviews
#83 |
Thanks, I remembered what you said and was wondering about that. What brand and model # is your new one?
#84 |
Same as it came with.
#85 | |
#86 | |
#87 | |
Hopefully, it is just a played out battery that won't charge, and the replacement will hold a charge. The final step in that battery testing is to start the engine and see if the voltage across the battery terminals goes upto 14V or more at 1500 rpm or so (good charging system).
#88 |
Good to know, thanx.
#89 |
Yeah the factory battery in the KPX is not very good. I had to change mine out in short order the Battery I put in there though has been great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300 |
#90 | |
