Old 07-10-2023, 01:29 PM   #1
RestockMotors   RestockMotors is offline
Venom X22R Max Issues
Hopefully Herbie or Jerryhawk will have suggestions or a fix. Anything at this point lol. I may have an issue with the throttle body, throttle cable, intake valve. The bike is Erving on its own. It is now bogging when I twist the throttle. It never shot flames out of the exhaust until yesterday and and produced black smoke for a second. This all happened as I took a trip to the gas station. With in 5 min of the ride, it stuttered and shut off. Started it back up but as I completed ride to the GS up the street, it continued to stutter and would not let me accelerate. Here are the codes my ODB II is reading. Please someone assist if you can.
ID:	29645   Click image for larger version
ID:	29646   Click image for larger version
ID:	29647   Click image for larger version
Old 07-10-2023, 02:22 PM   #2
JimS   JimS is offline
How long have you had the bike and how many miles are on it? I would first check the ground(s) to make sure they are tight and then check the MAP sensor to make sure it is seated properly and has no bent pins. Also make sure the battery connections are tight. One bad sensor/circuit can lead to a number of codes that other sensors rely on.
Not being familiar with the X22R, I don't know if there is an adjustment screw on the throttle body for bypass air or not that may need to be adjusted so you might want to see if there is one and if you can adjust it. I'd try one way and see if it helps/hurts and then the opposite way.
Old 07-10-2023, 02:38 PM   #3
J4Fun   J4Fun is offline
With in 5 minutes of the ride you say the problem happened. That’s the part thats bugging me. Long time setting with low fuel? Just washed the bike? in other words any chance water got too the fuel. One other thing my ‘22 Subaru Ascent had lots of crazy codes going on one time I got fuel and didn’t tighten the gas cap enough…just some thoughts
Old 07-10-2023, 02:44 PM   #4
I’ve had the bike for 2 months it has 406 miles. I haven’t had any issues until yesterday. I check the bike bolts before every ride. I also use the ODB II reader once a week and got no codes until the bike started acting up yesterday. That’s when I ran the reader and the codes I got. It won’t run right, bogs on throttle acceleration. Because the air intake code is showing, I removed the air box and put on a cold filter. I also re-seated the tmap sensor as well as swapped to the OEM Tmap sensor to no avail.
Old 07-10-2023, 02:46 PM   #5
One other thought, how’s the battery?
Old 07-10-2023, 02:47 PM   #6
The bike is full of gas. I never let it go past 3 quarters and I use 93 premium just like my R3. This is mind blowing. So far I’m getting answer of throttle valve but nothing has been confirmed. I’ve also had no experience with throttle valves.
Old 07-10-2023, 02:49 PM   #7
The battery has no issues but I am going to replace it with my new noco lithium battery.
Old 07-13-2023, 05:08 PM   #8
I checked the cables once again and the sensor was not all the way connected. I missed it the first check. This through the bike for a loop. Once I reconnected, the bike went back to working perfectly lmao Smdh I was loosing my mind. Thank you to everyone assisting
Old 07-13-2023, 05:13 PM   #9
bigdano711's Avatar
When giving connectors a once over, I will disconnect, re-connect just to KNOW that it was done and to hear the satisfying "click" when the locking mechanism snaps into place. This will help to keep oxidation down by scraping the connectors. Also, add a smidge of dielectric grease with a toothpick to each pin.
Old 07-13-2023, 08:50 PM   #10
herbie   herbie is offline
I’m glad you got it sorted out. Sorry, I just saw this
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 07-14-2023, 07:13 PM   #11
No problem Herbie! Thank you all!
Old 07-15-2023, 07:55 AM   #12
Venom 1   Venom 1 is offline
Glad that worked for you..A no $ fix is always a bonus.
Old 07-15-2023, 12:01 PM   #13
That's a NEW YORK FACT!
Search this Thread:
Advanced Search
Display Modes
