06-23-2023, 12:56 AM | #1 |
Brozz 250 broken clutch bolts
I am a new owner of a ‘22 Brozz recon and have been doing some upgrades. I just recently attempted to install some upgraded clutch springs and sheared off one of the bolts holding the springs in and I’m not sure how to go about fixing this. My question is should I replace the whole clutch basket or just the screws and where can I get the correct parts? If anyone can help it would be greatly appreciated.
06-25-2023, 04:17 PM | #2 |
I did the same with my TBR7, I pulled the whole basket out, and using a drill and small drill bit, was able to drill into the bolt, from the front(not the head side) and as the drill bit, well bit into the bolt, it screwed the bolt out.
Once out, I bought new bolts at like a Lowes. I believe the bolts' torque is measured in-lbs, I just hand tighten them with lock-tite. It's what I did, hope all goes well. |
06-25-2023, 07:48 PM | #3 |
I’ll try that thank you sir
06-26-2023, 12:24 PM | #4 | |
brozz 250, clutch assembly, clutch issues |
