Old 06-22-2023, 11:40 PM   #1
JadenHamilton   JadenHamilton is offline
Razz Vader Grom Compatible Parts
I’m about to change the front forks and my swingarm. I wanted to make sure all grom oem parts would fit the Vader. I’ve only seen one other thread on it and it didn’t say too much. Should I change the stem aswell? Just want to make sure everything will fit on before I get all this. Vader is a beasttt
Old 06-23-2023, 06:54 AM   #2
I’m planning to get a set of front forks off of AliExpress that Goblin mentioned. Will the Grom OEM swingarm still work? If I’m wanting to change the steering stem aswell where should I find a replacement parts?
Old 06-23-2023, 12:14 PM   #3
Deckard_Cain   Deckard_Cain is offline
First off, clarify... are you changing the front forks, or the front triple tree assembly?
The fork tubes themselves interchange. Rear swingarm does as well. I'm using a Grom axle and swingarm bolt myself.
Old 06-24-2023, 11:17 AM   #4
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
I am using a Grom swing arm. I had to mill down the bushings to get it to fit. I am using Grom axle bolts and cush drive dampener. Still haven't changed the bearings to the Grom bearings but that will happen one day.
I'm using some forks from AliExpress that were a direct swap.
Those items are good fits.
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
125, forks, grom, swingarm, vader
Search this Thread:
Advanced Search
Display Modes
