Old 06-21-2023, 11:12 PM   #1
RicePowerBaby   RicePowerBaby is offline
Old GY200 Help with wiring harness
Edit: Figured out the model. I updated the title.
Hello all.
Recently decided to pick up a project bike. Just by googling, seems its a 200GY. Engine stamp says HS163FML which led me here.
Going to strip all the broken lights, gauges etc. Needing to figure out what basic pitbike wiring harness I can use on this. The cdi was missing on this and the plug cut off. I included a pic of the stator wires if that helps. This original harness is hacked up.
Does anyone know if this would be the correct harness shown HERE?
Any help is greatly appreciated. Thanks
The wide plug is coming form the stator. What is this green plug?
Old 06-22-2023, 12:38 AM   #2
DrewsBrews   DrewsBrews is offline
DrewsBrews's Avatar
Judging by the head it looks like a 250 more than the 200. And it looks newer than the frame. That rear brake caliper mount seems rather unique. Possibly a Frankenstein build? I don't know what the other frames and gas tanks look like naked so I'm not much more help unfortunately.
Old 06-22-2023, 06:46 AM   #3
Mudflap   Mudflap is offline
The engine number indicates it's a CG200 and the frame looks like my old 2007 Lifan 200. The HS in the engine number indicates it was made by Hensim? Back in 2007 many similar bikes were imported and sold as Lifan 200s or generic GY200s. My Lifan had a 6 pin AC CDI but not the same as a GY6 CDI. The wiring harness for a horizontal engine pit bike will not work.
Old 06-22-2023, 08:54 AM   #4
Thanks for the info!
If anyone can point me in the direction of a compatible complete wiring setup I would greatly appreciate it.
Old 06-22-2023, 09:16 AM   #5
HS is either Hisun (i don't recall them bringing in dual-sports, but maybe they did), or the much more popular Hensim as you mentioned-- Hensim now known as RPS. There was a company called HiBird which had near identical clone bikes of the Lifan GY-2 model (as opposed to the VERY popular GY-5 model) and if memory serves me they were a contract manufacturer for Lifan, so it made sense that their bike was identical to the GY-2.
Hensim and HiBird were also two of the first companies to bring in dual-sports that were over 200cc to the US market (offered as '250'). The only other company that had bikes offered as '250' was Asiawing which seemed to be a one container special.
Old 06-22-2023, 11:28 AM   #6
Awesome thanks ill try contact Lifan.
Would this AC setup with 6 pin cdi work? Seen HERE
Old 06-22-2023, 09:15 PM   #7
I ordered a couple wiring kits, hopefully I can figure it out. If anyone has any info id greatly appreciate the help.
Gonna need cleaned up.
Clutch side seems OK
Found seals and gaskets for it. I would like to see this baby rip again.
Old 06-24-2023, 09:49 AM   #8
Thanks for the help. Still learning.
Search this Thread:
Advanced Search
Display Modes
