Where to buy Lifan motorcycle parts?
Brother, does anyone know where I can buy my motorcycle parts online?
Tried Aliexpress and Alibaba but none of them seems to have what I need. Are there any alternatives? ![]() |
Just click on what bike you are looking for parts for and you will see the available parts. https://kpclubusa.com/collections/motorcycle If you don't see what you are looking for then contact them contact@americanlifan.com (909) 775-7068
#3 | |
Look up freight forwarder companies. They exist to let you buy products from USA stores and have it delivered to a USA address. They then package or consolidate orders and ship it overseas to you.
Here in the Philippines I use shopee.ph or lazada.ph if I want to save a few Pesos. That isn't going to help you much if you're in the states. The parts are dirt cheap. It's the shipping that's a killer. Have you tried made-in-china.com?
What do you need ,walmart sells everything.
kp250, lifan, motorcycle, parts |
Thread Tools | |
