can anyone help me....my bike just recently started spuddering and will redline at 30mpr....put knew carb on and is still doing the same thing....
Have you ever done a valve adjustment yet? If not, do so.
#3 | |
Let's assume that is a typo... mph, not mpr That scooter has a CVT type belt drive. If the CVT clutch fails to compress the belt it will remain at lowest gearing. So it will redline instead of remain at moderate rpm as you go faster. Your CVT drive clutch assembly might need attention.
