#16 |
I still can't decide between the Xpro titan or the trailmaster TM31, my use will be 100% mud I don't intend to put a license plate on it and take it out on the road
#17 |
I wonder if other chinese imported products suffer from the same lack of concern when it comes to packing and handling. I mean, when Walmart gets a big skid of chinese dvd players, do some have birthmarks?
2022 Hawk 250 |
#18 | |
You've got to be specific with vendors... I am working on a return to AliExpress, and FINALLY got indication of a reimbursement. I had to be real clear with them ( for their translation to Chinese). Not sure if would understand what birthmarks are.
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 03-31-2023 at 09:53 PM. |
#20 |
Templar start/run/off switch
Still no word from PSM/Xpro, have been regularly checking spam folder. I find it annoying that a company that has an ad on the forum acts this way. Looks like I am going to have to continue going down the road of finding "aftermarket" pieces to replace things. First item was the sticky starter switch.. The closest I could find a couple weeks ago was just a little wider/thicker.
Taiss 12v 7/8″ Universal Motorcycle Starter/Kill Push Button Switch SW-02 ASIN B08FHMXVYW on amazon. This switch is available from several sources. ![]() Got this installed a couple days ago. I did end up swapping all wiring over from the stock switch as the provided harness had wrong contact/pins and some different color and extra wires, and I didn't want to splice. Of course, after I received it I found what looks like a couple options for the exact same style as oem Templar-x. Couldn't find them previously. One looks like oem, including connector, for $8.99. Wish I would have found this one before I gutted and rewired the Taiss. It actually popped up when I was searching for something else. GOOFIT Two-Function 7/8" Handlebar Switch Button H054-048 ASIN B09JKG94B5 ![]() The other is for a Suron e-bike application that looks like it could be repurposed...... for $20.99 ![]() Switch Assembly for Sur-Ron S/X Electric Bike ![]()
2022.5 X-pro Templar-X 6 speed undergoing break-in. 130 main, 42 idle, shimmed needle .042", 2.5 turns out mixture. 142T rear sprocket. CAT delete "kit". Modified starter interlock. 2022 Pioneer SHNG - SSR XF250. Sigma Jet Kit, Muffler & Air inject delete. |
