01-31-2023, 05:31 PM | #1 |
Modding The TBR7
Early last year I won a contest where the prize was a 2021Tao Tao TBR7. I enjoyed this bike as is for the riding season. Now I'm letting the mod bug bite. So far I have an aftermarket exhaust at first I bought the cheap VM26 clone carb now I bit the bullet and bought the NIBBI performance carb I've also bought a better chain and a 16T font sprocket and the digital dash. I have a few more mods I would like to get so stay tuned. I will also give my opinion on performance gains with the NIBBI carb and exhaust.
01-31-2023, 05:42 PM | #2 |
I just wanted everyone to know with the NIBBI carb you will need the NIBBI intake manifold and you will have to cut the manifold a bit so the carb and air filter will clear the frame at least on the TBR7.
01-31-2023, 05:47 PM | #3 |
Have fun with the mods. Nibbi also make the PE28FL and PE30FL which has the same flange mount as the stock carb.
https://www.amazon.com/Motorcycle-Ca...xpY2s9dHJ1ZQ==
02-01-2023, 10:51 AM | #5 |
I have my TBR7 set up similar to yours, but I plan to start doing some internal mods soon, and will be installing a fork brace. The fork brace evidently makes a noticable improvement, at least on the Hawks. Dan, and Jerry, and I'm sure several others have them. I should have had my engine mods done, but things have came up. They will be a home port job on the head, a thinner gasket, and maybe shaving the head a little, also a 4 degree advance key, and a longer duration cam, with roller tip followers.. My bike is actually pretty satisfactory on power now. I am running a 17/46, and have no need for any higher gearing. My stock speed odometer is accurate, which is evidently not common, but the bike runs 55 at about 6,700 rpm, according to the cheap little inductive tach I have. I also intend to install an oil cooler. There are other small mods that people do to these bikes like folding shifter, and wider foot pegs. Some go with better handle bars as well. I will add that it's not a bad idea to replace your rear sprocket studs with Honda studs.
02-02-2023, 03:03 PM | #6 | |
02-03-2023, 08:49 AM | #7 |
Change that stock chain. My opinion: https://mymotorcycleblog.com/upgrade-tbr7-chain/
HTH and congrats on the bike! |
02-03-2023, 12:14 PM | #8 |
Get some good tires, didn't like the stock ones that came on bike. Put knobby tires on mine,now can ride any time. Stock tires will just slide right under you in wet or muddy ground. But if you just going to ride on road mostly might be good. Did not feel safe on wet roads.
02-03-2023, 05:49 PM | #9 | |
02-03-2023, 06:05 PM | #10 | |
I should put these on Craigslist, but have been lazy even though I took pics! |
02-04-2023, 12:14 PM | #11 | |
02-04-2023, 12:27 PM | #12 |
4.10x 17 on back,and about the same size as front was. thinking a little bit wider than stock. made a biggest thing i've done to my TBR7. But i live in the woods and don't ride roads very much. Just closer to good thur the woods ,fields,logging roads.
