TBR7 wobbling.
So I got into an accident on my TBR seven I got it all fixed up and now it’s starting to wobble slightly once I go over 55 it’s not like a death wobble it’s very subtle but noticeable. I just took the front end apart and realized my fork seals are blown does anyone have an idea where to buy them preferably on Amazon. And would that cause my front end wobble?
Wheels take an impact during the accident? The rim/s may be out of round and need looking at.
Wheels true?
Be sure to check for notched steering bearings. Doesn't take much of a hit to dent the races if they use ball bearings instead of tapered rollers. That will definitely make it wobble.
tbr7 |
