#16 | |
The Nibbi 30mm is overkill for this motor, especially without port work or a cam. The pe28 is a much better match and can provide aome benefit even with the basic upgrades. Even with port work and a cam I found the 30mm to be just a tad too big and it still suffered from too big carb problems, such as being very sensitive to atmospheric changes. The PE28FL bolts up to a stock manifold as well, so it has less headaches to overcome.
#17 | |
https://www.amazon.com/Motorcycle-Ca.../dp/B09KXTVTGR Are you referring to this one? Can you point me in the direction of a 105 that would fit the stock carb? Also, would I need to purchase and run a 105 in the PE28 as well? or would it change based on the different carb? |
hawk 250 |
