07-15-2014, 03:51 AM | #1 |
Zongshen 250cc oil specs please?
Hi guys can anyone tell me the quantity of oil for a Zongshen 250cc motor, the type of oil and also the model of oil filter?
Thanks! |
07-15-2014, 08:35 AM | #2 |
Honda (cg/ cb OR Rebel) clone?
1.Refer to it's type 1st 2.http://www.shell.com/rotella/products/tpl-pro.html MA rated & CHEAP 3. If it's REALLY f***ed, follow ~09:00 in above is what u need.
07-15-2014, 11:25 AM | #3 |
Rhino's engine is in a quad, so it would be about a litre.
Rhino, if you have a sight glass, trust it instead of a dipstick. X2 on Rotella or any 15W40 diesel oil.
07-15-2014, 12:11 PM | #4 |
X3 on the Rotella, 15W/40 motor oil. I also like Chevron, Delo 15W/40, and Mobil, Delvac 15W/40 motor oils.
07-15-2014, 08:53 PM | #5 |
Thanks guys!
08-13-2022, 10:11 AM | #6 | |
The 176FMM CG250 has a filter mesh/screen under a 24mm cap/spring that holds it in (look behind the gearshift lever). Rotella T4 15w-40 is compatible with the multi-plate clutch. It takes about a quart. Start there and adjust if necessary. If you have the sight glass, It should be ~70-85% up in the window (can see an air bubble in the window). |
