There's always the cheap zosntes alternative left, but I don't know about the reviews for that motorcycle.
Length (mm) 2085 The body Aluminum alloy Frame system Iron pipe frame Width (mm) 850 Cylinder number Single cylinder Tire structure Radial tire Height (mm) 1320 Camshaft system Double-top camshaft(DOHC) Front rim size MT:3.5×17 Wheelbase (mm) 1395 Bore X Stoke (mm) 84.5 x 62.0 Rear rim size MT:4.5×17 Loading capacity (kg) 182 Cooling system Water cooling Front tire size 120/70ZR17 Curb weight (kg) 196 Fuel 95 and above Rear tire size 160/60ZR17 Ground clearance (mm) 150 Compression ratio 12.3:1 Front brake size Disk brake Fuel tank volume (L) 19 Displacement(ml) 348 Rear brake size Disk brake Seat height (mm) 795 Fuel supply system Fuel injection Headlight/taillight/turning signal light LED Fuel injection system BOSCH Brake system Dual channel ABS Ignition system Electric ignition Transmission system Oil sealing chain Idling speed (r/min) 1650 ± 100 Maximum power (kW/rpm) 29 / 9500 Maximum torque (N.m/rpm) 32.8 / 7500 Transmission Constant mesh 6-section transmission G ear International gear Clutch Wet type multi-pieces Economical consumption of fuel (L/km) 3.2 /100
