05-18-2022, 08:40 AM | #1 |
Lifan X Pect owners?
So I've been wanting a dual sport for 20 yrs. Ended up with a cruiser (86 VS700) that's served me well for 12 years.
Last night, I was introduced to the Lifan X Pect and I'm thoroughly impressed except for a few concerns. For those that own them, especially in the northern half of the US/Canada (I'm in eastern PA), please share your experience with the following issues.... 1. Winterizing- What's the process of getting the bike ready for storage in the colder months? With my carburated Intruder I had to shut off the pet cock and let the gas run out. Then just change the oil in the Spring each year. 2. How do warranty claims work- There's not another Lifan dealer for 50 miles and I just found out there's a mechanic willing to work on them if I bring them the parts about 25 miles away. How/what does Lifan support and cover costs? 3. Care/Maintenance- Other than changing the oil/filter and air filter....what care and maintenance do these require? 4. Finding parts- The mechanic 25 miles away said parts can be very difficult to come by for these (China bikes) because they are made for a couple years then they change the models/builds. I'm not worried about upgrades but what if a crucial part within the motor/controls breaks?? How easy is it to find all core components IN STOCK? 5. Upgrades- Thinking about adding saddle bags. Maybe a folding shift lever. What else do people upgrade on these and why? 6. Problems- In watching a lot of vids the valve adjustments, which just requires a socket and feeler gauge, what are known issues with these bikes....whether it's upon delivery or two years down the road? I've also...quite frequently read about cross threading and stripped nuts....what's the fix?? 7. Anything else- Please feel free to share anything else I didn't think to ask about. THANKS!!!!! |
05-18-2022, 09:55 AM | #2 | |||||||
kpclubusa.com The entire bike is there in parts. You just select whatever part you want, fill up your cart, and they ship it out in like 24 hours. It’s here in the United States. All the parts are right here in the United States. They get to you in a couple days. I’ve had nothing but great experiences with these people. They even sent me a free Lifan hat because I’m probably a shill online for them and I don’t even realize it. Lol. Not associated with them in any way. I have just broke enough stuff on my bike and ordered enough stuff like that from them that maybe they noticed me. Quote:
More about the bike itself. It’s really reliable. You can forget about that stuff. If you weigh a lot, it might feel a little slow. The seat height is also a little bit low. At least for my taste. It’s flat foot with knees slightly bent. I would prefer a couple inches higher. I wear 30 inch pant legs. But I guess the good part is anyone can just get on this thing and ride. The stock gearing will keep you at about 55 mph on the street at 7000RPM. Too slow for the highway. Secondary road and off road bike. Keeping that gearing makes it nice off-road. It’s perfect off road. It’s a bit underpowered if you are used to really spinning that back wheel. But it has enough power to get you around and go up whatever hills with all of your gear. It’s a little challenging finding neutral with all of these Chinese bikes. Better to go from second into neutral than from first. It seems to find it easier. A lot of people on the Forum gear them up a little bit with bigger front sprockets. I didn’t do it because I like the low end stuff off road. If you ride just about all road, you should probably change the gearing a little bit. I don’t think there’s much else to it. Just go riding. That’s what I do. PS: I’m currently on the NY/NJ border now in case you want to see an xpect in person be do you order it. Not promising a test drive, but, you can take a look if you like.
2020 Lifan x-pect Last edited by Boatguy; 05-18-2022 at 04:13 PM. Reason: Bad website address. |
05-18-2022, 10:57 AM | #3 | |
Thanks for the info. See the bolded replies above. |
05-18-2022, 03:37 PM | #4 |
As noted, this website is owned by Lifan and sells parts. When you're ordering from here, you're ordering directly from Lifan. When I placed my order, the company emails actually came from an American Lifan email account.
https://kpclubusa.com/ Free shipping, as well. |
05-18-2022, 03:39 PM | #5 | |
Go through your dealer and get the parts mailed directly to you. That's what happened with my X-Pect that had a front rotor damaged in shipping. I contacted my dealer, Venom Motorsports, and had a new rotor in my mailbox three days later. I think the warranty only covers parts, not labor, but I never read all the fine print. |
05-18-2022, 03:39 PM | #6 | |
Much appreciated. This website might be my saving grace and what gives me the ability to feel confident in ordering the bike. However, I don't see motor parts listed at all. I can understand the frame not being there because it's serialized. By why no motor components? Thanks |
05-18-2022, 03:42 PM | #7 | |
Other than adjusting valves and other normal maintenance, the only significant issue I remember seeing is the wire loom rubbing through and causing electrical problems. I think it happens where the wiring harness rubs on the head tube. It's constantly moving when you turn and that cuts through the insulation on the wires. Maybe a good idea to wrap that area in some further protection. Also, my factory chain was wearing quickly, so I replaced it with a 128 link JT sealed chain. The replacement chain was better quality than the factory one. |
05-18-2022, 03:45 PM | #8 |
One issue that no one here has mentioned is that the tires/wheels are an uncommon size, which really limits your replacement tire options.
There are some options out there, though. I ended up replacing them with Bridgestone AX41 tires. 90/100-19 front and 4.60-17 rear. These aren't cheap, but perform well both on and off road. |
05-18-2022, 03:47 PM | #9 | |
The engine is a Honda CG clone, so parts are not hard to find. Also, I think you can contact them to get parts not listed on the website. |
05-18-2022, 03:50 PM | #10 |
"I've been seeing a LOT of people mention front sprockets. Confused a bit there....wouldn't the rear be more important to swap out since the chain wraps around that??"
Adding teeth to the front sprocket is the same as subtracting teeth from the rear, so it doesn't matter which you do. Last winter I left a full tank of gas in the bike, and just pushed the starter button about five months later. It started right up like nothing happened.
05-18-2022, 03:51 PM | #11 |
So quick update....
I think I'm going to order one. If not in the next few days then as soon as I sell my current bike. I've done some calling and driving around today and I THINK I've covered all the bases to allow me to feel confident in ordering the X Pect but I'll list everything and would appreciate some thoughts. 1. Contacted the notary I usually go through. They mentioned the "L" serial number and said as long as the MCO lists the seller and is complete.....I can get a title and registration/plate sent to me through the state no problem. 2. Contacted PowersportsMax. They DO send a completed MCO AND will take care of all warranty claims for parts. So I send them pics of faulty parts, they send me the parts. 3. Contacted American Lifan.....which seems to be just a phone line that's still routed to China (same for PowersportsMax....both of which spoke broken English). They said the 2 year warranty is only for parts if bought online and not labor.....fine. They also verified that PowersportsMax would handle all warranty and MCO issues. 4. Drove to my local mechanic that I normally use. Wanted to talk to him in person to make sure I had his attention and that he understood me. He can get tunnel visioned sometimes in conversation, but does EXCELLENT work. He confirmed so long as I gave him ALL PARTS, he would be willing to do any work needed on the bike. But since he's a small shop, he said major repairs would have to wait until he is slow possibly in the winter time. That's good enough for me!!! So now I have cleared the way to get it titled and registered, parts covered under warranty, and a mechanic to do the repairs in case I ever need it!!! Great!!! All that's left now is to contact Progressive and see what they want to insure it. It's usually like $75/yr for full coverage so I'm not worried but that....and talking to my wife about when to buy it....is really the last steps. Thanks for the replies thus far. Please keep them coming! |
05-18-2022, 03:52 PM | #12 | |
Thanks |
05-18-2022, 03:54 PM | #13 | |
Ok, that makes sense. The front is a lot easier to work on. No chain, drum, etc. Do these have reserve tanks and a pet cock or is it just relying on the fuel gauge to know when to fill up? Thanks! |
05-18-2022, 03:56 PM | #14 |
Just go buy it and hide it in a friend's garage. It is important to have intrigue and drama in a relationship.
First two things to do when you get it: change the shipping oil it comes with to actual 15W40 motorcycle oil adjust the valves. Lifan says .006". Chinese factories always seem to adjust them too tight.
05-18-2022, 03:57 PM | #15 | |
I paid right about $200 for the set from Chap Moto. Bridgestone had a $50 rebate at the time, so after that I paid $150. I installed them myself. There are some cheaper options. I haven't looked in a while, but based on my past research these tires should all have sizes appropriate for the X-Pect: Kenda K761 IRC GP-1 Shinko 244 Bridgestone AX41 I think there are continental tires that will fit, but I don't remember. |
