02-09-2022, 12:55 AM | #1 |
Tbr7 won’t crank over
Alright so I have a 2021 tbr7. I have been riding it for a while with no problems. Recently I noticed it is having trouble starting in the cold. I live in Texas and we recently has some freezing temperatures. The other night I couldn’t get it started. I tried to start it for a bout an hour. The electric start just wasn’t doing it. The kick start was getting it started for a few seconds then it would sputter and die. I tried to jump start it with my car. Probably a real stupid idea because not it’s completely dead. Like the battery has zero charge and lights won’t turn on at all. Pretty sure I blew a fuse or shorted something out. Any help would be well… helpful.
02-09-2022, 07:34 AM | #3 |
Are you using the choke when you are starting it?
02-09-2022, 08:49 AM | #4 |
Did you adjust your valve lash? A symptom is hard starting when cold. Also get rid of the stock spark plug if you're still using it.
03-02-2022, 06:49 PM | #5 |
If you still are using the stock carburetor and haven't changed the main jet, the settings are exceptionally lean. I have an older TBR7 and re-jetted it to a 110 and usually don't need the choke to start when it is warm, but in cold weather the choke is needed. Perhaps a bit of starting fluid may get it going, provided you have spark.
03-04-2022, 08:30 AM | #6 | |
