02-22-2022, 08:04 PM | #16 |
I might be cussed, but to me a stock chain just plain sucks. Tubes, chains, grips, fuse holders, brake lines, grade of bolts on minor pieces, are all places where an OEM cuts costs. Hell, Yamaha used to shave an 1/8th off their handlebar width on bikes they carried over year after year, knowing the end customer was going to toss them the minute they got them outside the dealerships. Chains on anything that was supposed to be used in extreme conditions, were decent at best. They usually lasted about 3 weeks. On anything else, cheapest they can get, complete shit. Replace items listed above ASAP, your machine, plus your temper, will thank you.
02-22-2022, 11:57 PM | #17 | |
For me, speed isn't important. I want tractability in off road and gravel/sand/berm and trail conditions. Street legal for me means I can drive to the fun. But your preference might be different. You won't know until you ride it. How many miles are on your TBR7?? Last edited by Thumper; 02-23-2022 at 09:14 AM. |
02-23-2022, 07:20 AM | #18 |
I have a total of -0- miles on it. It's still in the assembly stage. Haven't even started the motor yet. Been taking my time with the assembly checking everything out as I go. Referencing Megadan's "Hawk 250 Resource & Information Guide". Too cold here in Milwaukee to be in a rush to ride. Had a nice ice storm yesterday and don't have studded tires for this thing yet.
02-23-2022, 09:19 AM | #19 | |
My son's TBR7 isn't done yet either. I got a gallon of T4 15w-40 ready to change in when we can start it and heat it up to dump the oil hot, or at least warm! I don't like working with frosty tools! It will be back in the 60s next week. We will get there! |
02-23-2022, 09:55 AM | #20 |
This topic made me think recently about the chain on both of my dual sports after recently running thru some cakey mud, they need a nice cleaning.. found this deal on Amazon, looks like a super deal if it works well.
https://www.amazon.com/dp/B09B47LDK1...hk_typ_imgToDp
02-23-2022, 04:34 PM | #22 |
Speaking of changing the oil in a brand new TBR7, I went ahead and changed mine cold. Well, not real cold. I have the luxury of tinkering with this thing in the work room in my basement. Point is, I didn't run the bike to warm up before change. After all the comments about the break in oil used in these China bikes I expected to see some kind of mystery liquid come out. It looked like descent motor oil but, why take a chance? I put in the T4 15W-40. What is correct way to check oil level? After screwing in dip stick or resting dip stick on top of threads? There is no sight glass I could find as referenced in Megadan's guide. Next question, I was a bit surprised to see the accumulation of fine metal particles on the oil plug magnet. I drained from bottom plug. This indicates motor was run before it was shipped. I can only hope this is normal accumulation during break in and seating of rings?
02-23-2022, 05:38 PM | #23 |
My manual reads… “Insert the dipstick in the oil fill until it rests on the metal, do not screw it in.”
02-23-2022, 06:48 PM | #24 |
Hawks have a sight glass, if the tbr7 does not, use the dipstick as mentioned above. No matter what, they take right around 1 quart of oil, so add a quart and you should be ok.
As far as the metal. Yes, they test run the engines before boxing them up. During the first few hundred miles the oil will look like somebody poured confetti into the engine. That is why I change the oil after the first 300 to 500 miles.
02-23-2022, 10:54 PM | #25 |
I did fill it with a measured quart. I recall that was the correct amount from likely something I read on the forum. It seemed it was over filled screwing the stick in. I guess I could have referenced the manual, as Michigan Sportsman points out, and measured it correctly. I'll bet measuring it per the manual, my 1 qt. fill will be right on the money. Nice to know I don't have to suck some oil out. That always hurts my lips.
