adding a tach
I have a 2008 Rokata RKM it not a CDI bike I would like to add a tach and have been looking around to see where I would hook the tach to anyone have a clue?? any help would be great
Larry 2008 Roketa RKM-200E5, 200cc |
Im not sure, but it might matter what kind of tach your hooking up, a digital might be easier, Im sure someone else knows more!
not sure who makes it. but there is a company out there somewhere that makes a tach that connects over the spark plug and the spark cable connects over it. brother has one on his go-kart.
'09 Kawasaki KLR 650 '07 Zongshen 200cc Dirt Bike K&N cone filter, FMF Powercore Exhaust, Moose Barkbusters & lotta threadlock. |
try jegs performance part # 105-6652 mini drag tach = $115.
TRY a Tiny Tach you can find them only for around $35-37 Also try Ebay...
TINY TACH WEBSITE http://www.tinytach.com/tinytach/gasoline.php Here's how you install it. http://www.tinytach.com/tinytach/installation_gas.html
-2005 Sierra SR200- |
Sorry need to clear up somthing I have the tach already what I was trying to find out is with out a CDI unit where is the best place to wire the tach to? Should I wire it direct to the coil or is there a better way?
Thanks Larry
Great idea, simple, simple set up. Very neat srreynolds2003
If you have a Chinabike tach or another bike tach (I have replaced my tachless cluster with a Lifan cluster whith a tach), it will most likely need to be wired to the coil's primary(12VDC) wire. This is what I did. Works like a charm.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
Yes thats what I'm doing sounds like the same thing I got a Chinabike cluster whith a tach and also reads MPH I was thinking that I would have to wire to coil 12VDC side but was not sure if maybe there was a better way.. Thanks
Your bike MUST have a CDI. The only other option is points and/or a distributor and I AM SURE that's not what it has. If you bought a tach from a China bike it is more then likely mechanical and the Roketa engines (at least mine) do not have a provision for the mech drive assembly.
Red I think I have the same bike as you .. As for the tach I got is ele. setup not mechanical.. As for the CDI I'm sure there is one some where but not under a plate like on some that say CDI ..
The CDI is a black box under the seat.
Allen
#13 |
Thanks I can look at that also
#14 | |
#15 |
For a while I thought this bike was 50 years old. :wink:
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
