#211 | |
Out of stock on the fenders but I loath the Storms fender big time anyway. It's nice and long, just long enough to shoot the rain out in front of the bike and up just high enough in a stream to hit you. ![]()
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
#212 |
That was just an example of what I was describing. There are many fenders out there like that.
#213 | |
#214 |
just build a half way descent gaud around it...
something like this.. http://www.chinariders.net/showthread.php?t=22212 ..
#216 |
Hello and Happy Easter! I read this thread, and I had a couple questions...
1. Id like to order an oil cooler for my Hawk 250. I prefer not to buy anything thats going to take weeks to get here. 2. Is there an all in one kit (something I dont have to bend, build mounts etc)? 3. I went to Hawk250.com but couldnt find an oil cooler link. 4. Thanks for any info! |
#217 |
After going through some more posts, including the sticky from MegaDan (thank you) ...I found this link https://www.amazon.com/KIMISS-Alumin...oding=UTF8&me=
With this version what else is needed to get it set up. Thank you! |
#218 | |
Nothing thats the one i bought and it came with everything i needed to mount and install it take your time with posituining caise those bolts are pretty long amd caused some frustration but i didnt feel like going to the hardware store after i had it halfway together also the brackets are really thin but ive taken it through some gnarly stuff and its still where i put it. |
#219 |
Great! Thanks for the info.
#220 |
Question
Would this upgrade work on 2020 brozz 250
#221 |
Absolutely. The only thing to take into consideration is what size cooler you want, and then where you want to mount it. If you have it mounted high like mine where it sits behind the front fender a bit, it might take a little shimming of the front fender rear mount(s) to buy it the space it needs.
#222 |
Would this upgrade work for my tekken 250? I think the engine it has is loncin lx166fmm (re250)?
https://www.aliexpress.com/item/1974582999.html |
#223 | |
#224 | |
#225 | |
It might calm my concerns to just install mine at sump level and add a debris guard, but it looks really good how you have it installed. Megadan: I like your thoughts on the fitted oil lines.
2021 Lifan Xpect EFI 2012 DF250rtc 1982 Yamaha Virago XV750 1982 Honda Twinstar CM200 |
