#46 |
Thanks! I’ll be sure to get some photos on the next ride. To my surprise some of those sections at higher elevation actually saw a little snow last week, so we lucked out on the weather.
2013 SSR XF-250 |
#48 |
Would you ride the RX3 on the same route?
#49 |
Yes I would. I thought about taking my RX3. My only concern would be the stock tires. With some better off road tread DOT tires it shouldn't be a problem. The challenging area would be riding through the decomposing rock starting around 13:14 mark. At the 14:15 mark I took a spill when my front tire washed out. Combination of over correcting and tires at highway pressure.
2018 TT 250 2016 RX3 1979 CB750K |
#50 |
Novice
What pressure would be appropriate to air down to for those rocky trails? Also, what gearing are you running?
Hopefully this heatwave will be gone in a week for the next ride.
2018 CSC TT250 - Fakuni - 115 Main/30 pilot/needle in 4th slot @ 700ft - 1.75 turn A/F screw - eBay exhaust - pod filter - 17/47 - NGK DPR8EIX-9 - Rotella T6 15W40 |
#51 | |
I was running 32psi with stock tires. I think 20 or 15 psi would of helped. When I change tires I will get wider tires with a little more aggressive tread. Not to mention more riding practice is called for. This weekend ride will be a hot one. It's going to be around 100°F(37°C). I plan to ride in Death Valley eventually so this will be a good practice run I guess. I changed my gearing towards highway speeds. I am running 17 in front and 47 rear.
