Old 05-21-2021, 01:20 PM   #1
Huntsman911   Huntsman911 is offline
Engine dies after full throttle run, TT250
Hey all,
I recently put in a new jet kit and fixed up the carb and air intake on the TT250, but I've been trying to get the fuel mixture just right. I thought I had it, but now the bike is dying Everytime I do a run on full throttle. I notice it always dies after I climb a hill on the road where I have to use full throttle.
I figured it was too lean so I richened the carb via the needle, but it's still doing it. Am I still too lean? Or am I running too rich from the get go?
Thanks guys
Edit: I should note, it's when I let go of the throttle after the hill when the engine dies.
Old 05-21-2021, 02:24 PM   #2
mtiberio   mtiberio is offline
mtiberio's Avatar
insufficient fuel flow, your petcock is your main jet
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami
Old 05-21-2021, 03:48 PM   #3
Petcock is open, I'll check the main jet. It should be bigger than stock with the jet kit upgrade
Old 05-22-2021, 07:41 AM   #4
franque   franque is offline
How does the fuel hose between the petcock and carb look? That's what he's talking about, and there's potentially crap blocking the petcock from within the tank.
Old 05-22-2021, 07:51 AM   #5
TxTaoRider   TxTaoRider is offline
Like the others said, check for fuel flow. If the line isn't kinked, try disconnecting it and let it flow into a gas safe can or jar. Let it flow for a couple minutes. If it slows or stops, then remove the gas cap to see if it's a venting issue.
If could also be a low float level setting in the carb. The aftermarket carbs I've gotten havent been even close to correct.
Last but not least, if you're still running the stock spark plug, they have been known to have fouling issues.
Good luck and let us know what it was.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 05-22-2021, 10:44 AM   #6
DSM   DSM is offline
What does the spark plug look like? That’s the first indicator of fuel mixture.
Old 05-22-2021, 11:16 AM   #7
Even more important, what does it look like right after it quits.
csc, engine, throttle, tt250
Search this Thread:
Advanced Search
Display Modes
