04-06-2021, 05:25 PM | #1 |
Which one of the Three
So I have enough money to purchase a new motorcycle.
The three I am looking at are the KPR 200 KPM200 Venom Ghost I like the idea of liquid cooling, and 6 gears. I am more of a cruiser guy. I had a csc sg250 and liked it but it was a little low on top speed. I am worried that I will be in the same boat with the Ghost. Any information to help me decide would be beneficial |
04-06-2021, 05:54 PM | #2 |
I like both the KPM200 and the Ghost. Top speed will probably be about the same. I did have to change the rear sprocket on my ghost because it was too low geared from the factory but did make a big difference on top speed. With the gear ration I'm running now on a completely stock engine, I can cruise comfortably 60-65 mph. Over the weekend i did take it out on the interstate for a short distance and maintained 70 mph with no problem. I'm sure I could of ran it up to 75mph. Not sure the state trooper following me would of allowed that. lol The CB engine does turn more rpm's than the CG engine.
04-06-2021, 06:07 PM | #3 | |
04-06-2021, 07:37 PM | #4 |
Not hard at all.
04-06-2021, 09:52 PM | #5 |
04-06-2021, 11:40 PM | #6 |
You probably want to change out the chain on the Ghost--most Chinese bikes, actually. I believe the Lifan bikes might have decent stock chains as those bikes are marketed as slightly 'higher-end' and more so considering their 'fancier' engines. Check out Jerryhawk's thread on his Ghost. Looks like a good bike and responds to modifications.
04-07-2021, 08:02 AM | #7 |
No, I still have the stock chain. I only have a little over 900 miles on the bike so far. The stock chain looks to be a good quality chain. It was well lubricated from the factory and so was everything else. The chain looks way better than what came on my Hawk and X22R and those lasted about 2500 miles.
04-07-2021, 12:32 PM | #8 |
I have the KPM 200. Depending on your weight, you can hit a steady 65 mph like me (at 250 lbs), or from what some reports have said 70 mph. I can't confirm the higher speed reports though, because the speedo is off considerably, and they haven't verified with GPS.
At the moment, It'd say go with the ghost. Parts are more standard and easier to find for upgrades. I'm making a list of things, but the rear sprocket has been a pain. It's not flat like normal sprockets. I've found one that brings the rear down from 49 to 45, but haven't bought it to test it yet. Also, thankfully, 428 chains are very cost effective. My stock chain is ready for it's 4th adjustment after about 200 miles on the last adjustment. I think i have almost over 2k on the clock right now, but because of the speedo being 5 mph faster than it should, I'm maybe really at 1700-1800 miles. I've actually kicked the chain before, It's pretty terrible. lol. |
04-07-2021, 11:01 PM | #9 |
I'll toss my two cents in since I was just having the same debate. If you plan to work on it yourself and mod the bike it seems like the ghost would be the way to go. The motor has a ton of available parts and you could probably find all the info you need just by surfing JerryHawk's threads. Just from reading his threads it looks like there are quite a few more to that motor that you could do to milk the top speed.
If you are going to buy it and run it as-is you would likely be happy with either. I went with the KPM since I liked the look better since I've never been a cruiser type person. The 6 speeds in the KPM are nice and the fit and finish is far beyond what most would expect from a sub-$3000 bike. Either way I think you will have a blast and likely get great support from the folks on here. |
04-08-2021, 07:57 AM | #10 | |
04-08-2021, 09:53 AM | #11 |
If you don't want to tinker, it would be better to get something used and Japanese that can be easily sold when needed, and serviced at a dealership. A CB300F or similar comes to mind. If even changing sprockets is more than you want to do, a Chinese bike isn't the best buy, as you'll at least need to adjust valves from time to time, and that is much more mechanically involved than changing a sprocket, and not many shops, even independent ones, will work on cheaper Chinese stuff like you've mentioned.
04-08-2021, 03:53 PM | #12 | |
Tinker is probably not the right word, I know there is a small amount of maintenance required (i.e. carb work, changing oil and such), I am just worried about major work. I can adjust valves, I have done that. I guess really it just depends on how much I get to ride vs down time because I screwed something up |
04-09-2021, 12:17 AM | #13 | |
