Where to this week? And I see you are still washing your bike at every stop!
I used four u=bolts and it bolted up good.
I saw the Brozz go down! It didn't look too bad, and you are not reporting injuries, not to mention you rode away, but I do think it couldn't hurt to have a second person with you!
So when you buying that Hawk from Eric so he doesn't have to ride alone? lol
Ironically, I would have to ride alone semi-offroad (staying mostly off the Interstate), or attempt a flat out run on Interstate 8 (posted at 75 MPH) for over 150 miles to get to ride with Musictrek.
#9 | |
#10 | |
The dead cows, too!
Don't let the haters get to you, brother! (Just kidding guys, all in fun!) I ride by myself because my friends aren't as brave as I.. You need to stand up more though! Especially in that stuff. I got ejected out at the dry lake bed in Vegas going ~60mph on packed dirt to straight sand. Flew off about 10ft., dusted myself off and had to dig my bike out lol.. no injuries.
Do you know how to stand the bike up putting your back to the seat, use one had to hold the front brake, another to grab the rear frame, then dip down and power lift that b!t-- back up? Really saved me with my 650 dual-sport @475lbs lol Also doing that helps reserve your energy and muscle dexterity for more riding! I MISS THE DESERT RIDING!! Jealous man - bike looks awesome! I like the rear saddle-bag; I have a tube on the side. Mine isn't as robust as the Brozz / Hawks - it looks like a straight motox with lights. Safe riding!
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
#13 |
Yours is essentially the same bike as the Orion RXB 250L with less features? Powersportsmax and their Amazon site are not showing them right now. I thought they were identical to the Orion, but people pointed out the X-Pro didn't have such features as the adjustable suspension and probably some other things.
https://www.orionpowersports.com/ori...embled-tested/
#14 | |
Very true, no adjustable suspension in the front; just bleeders. I can adjust the spring in the back - actually seems pretty solid though. The non-light version of mine is listed as an X-Pro Titan, with slight differences - my rear sprocket is only 4 bolts. Though the new Hawk bikes I've seen pop up on Amazon are now listed as "X-Pro Hawk". But they do have other strictly dirt bikes from X-Pro. Luckily I got a 21in front and 18in rear - apparently the 18in rear is more desirable over the 19in? Also, no mid-bolt on the exhaust to the frame like ALL the others. My exhaust is all one pipe. Finally getting to practicing with my welder so I can cut-n-gut the header. Also came about 95% put together (maybe txpowersports did most of the assembly?). I looked up X-Pro and... they make a crap ton of scooters so, maybe this a new venture for them?
