Brozz 250 electric starter issue
Hello everyone. I have a 2018 Brozz 250, 650 miles on it. The battery died on it once from me not starting it. I ended up pop starting it. Ran it for a while to recharge battery.
Now even with the battery re charged, the electric start won’t turn the engine over. It really tries but just can’t get it to turn. I have to pop start every time I want to turn it on. Anyone ever have a similar issue? Any help would be greatly appreciated! |
You need a new battery. If you let these little batteries go all the way down, they are usually toast.
Thanks for the reply. the lights and all the electronics are working with what seems to be full power.
I hope that is the issues seems to be an easy fix |
Probably need a new battery....you have 12 volts now that its charged,..powers lights just fine,..but you dont have enough amps to turn the starter...
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
That makes sense. I’m going to try the battery. Any recommendations on where to find a good price on one? Also, is it just a normal 12V motorcycle battery?
Really appreciate the quick replies! |
Get the number off your battery , and then search Ebay with that number, i recently got gel cell batteries which are very good for two of my Bikes off there for less than $35 each . , I'm sure the same Vendor has one that will fit your Brozz.,and they are much better than the stock one.
brozz 250, starter |
