06-16-2020, 08:31 PM | #16 |
Did you pull the tank to snake the wires or attach it to the fuel sender?
Anybody have a link to the digital speedo ? I have a 2019 TBR7 |
06-16-2020, 09:27 PM | #17 | |
06-17-2020, 03:01 AM | #18 | |
Here are 2 options most direct fit etc: https://www.ebay.com/itm/303590150927 https://www.ebay.com/itm/Tao-Tao-TBR...d/303590147637 Plug into stock loom - connect 2 wires and wheel sensor. No gear ind to mess with, no repinning as well as more funky feuters etc |
06-17-2020, 03:03 AM | #19 | |
https://www.ebay.com/itm/Tao-Tao-TBR...d/303590147637 Direct fit - no messing about with gear wires or re pinning the plug etc. |
06-17-2020, 10:35 AM | #20 |
with electrical thats how you avoid many issues...
06-17-2020, 11:38 AM | #21 | |
its not a struggle but the wiring on these bikes has a way of changing from time to time and not being consistent...thats why i think being more specific would be helpful.... i think you are using a somewhat vague description...... electrical connections are not vague but exacting.
06-18-2020, 02:23 AM | #22 | |
It’s 1 wire.... Big connector on hawks n TBR7 or some have a bullet connector like the CQR etc Um.... I don’t see vagueness but I did mention using a little common sense.... Sorry but I fail to see the drama as America is a smart place n went to the moon.. so I’d assume there’s gotta be a little common sense in everyone to find 1 equally colored wire....... |
06-18-2020, 02:28 AM | #23 | |
Plug or pin out might but simple common sense solves that. Also common sense as to how you want to run the wires or finish it off is up to the installer.... The TBR7 is the easiest most basic to instal - plug in the logical plugs directly no gear wires needed as it plugs to stock loom, run 1 battery wire and 1 tachometer wire.... I really fail to grasp with a little thinking how this is so complex.... |
06-18-2020, 10:48 AM | #24 | |
My speedo is accurate within 2mph at 55mph. All lights and functions work as expected. Like you say about connecting the tach wire, it's common sense and easy. The gear indicator wires were stupid simple too. Literally match the colors and stick them into the plug until they click. There's a 6th gear wire and a purple wire not used. Boom! Done! I agree though, people are making this out to be so complicated... It's not. |
06-18-2020, 08:12 PM | #25 | |
There’s a thread with a guy who bought that other speedo and can’t get it to work... I pin mine as per customers needs and as you see in my thread I’ve got 2 option and several extra things in mine that just make it a bit more then a basic setup like this you got. Hey I’m bias! |
06-18-2020, 10:15 PM | #26 | |
Doesn't yours have variable backlight colors? Curious about the extra features... |
06-20-2020, 11:40 PM | #27 | |
Some clock or volt meter Power out plug for usb Dial in for all wheel sizes by the centimeter Bross or TT style. Can change all parameters to suit other needs etc Just more changes you can make to customize to your taste or needs Everything any other has mine has but I added more options etc |
