Old 05-28-2020, 05:04 AM   #1
Bahamutflare36   Bahamutflare36 is offline
Chain link amount Hawk & Tbr7
Hey guys, so bought a Hawk and Tbr7 for me and the wife. We have ordered a 40 rear sprocket for the Hawk but sticking with 15 front, and for the Tbr7 have a 17 and 42 combo ordered, whats amount of links of chain for each would be recommended? Also when placing new sprocket and chain it is best to slide axle all the way foward toward engine correct?
Old 05-28-2020, 06:00 AM   #2
Not entirely sure on the TBR7, but for the Hawk it's fairly straight forward. Stock with a 15/50 is 130 links That tends to work ok down to a 17 front and 45 rear. When ran a 43 rear I found a 128 links worked much better. 128 may work even with a 17 and a 40. With a 15 and a 40 though, 126 links may work a little better.
Those are just guesses though. The best thing you could do is order a chain you know is a little too long and then use a chain break to shorten it to what you need.
As far as putting a new chain on, yes it is ideal to slide the rear wheel forward to setup your chain. The stock chains don't have a master link so you will have to either break the chain or remove the rear wheel, and then the swing arm so you can thread it through the chain. Obviously breaking a chain is easier.
A good chain tool kit is a good investment to have if you don't have one. Some of the more affordable ones are made with cheaper materials so if you don't use them intelligently they will tend to break or have other problems. The best thing you can do to break the chains is to grind the riveted ends off of the pins on the outer link before using the press on the break tool. I have a Pit Posse tool that I have done dozens of chains with and had no issues. https://www.amazon.com/Pit-Posse-Mot.../dp/B004MS9VTW
Old 05-28-2020, 02:41 PM   #3
Awesome i will probably just go the 130 link chain route and break it to size i need! Also when i take old chain off, i do turn the chain adjusters as far counter-clockwise as possible to reset and have full adjustment?
Old 05-29-2020, 04:34 AM   #4
To put slack in the chain, yes you would turn the adjuster nuts counter clockwise and back them off as far as you can so you can slide the wheel forward. To get the chain off the bike you will have to break it since it is fully riveted and does not have a master link. Good practice for the new chain.
Old 05-29-2020, 11:55 PM   #5
Awesome thanks for the help!
chain, links, sprocket
Search this Thread:
Advanced Search
Display Modes
