#226 |
Bags look great!
#227 |
Yeah, the bags are fantastic quality. I’m very happy with them considering the reasonable price point.
I should hit 1000 miles this weekend. That 72mpg number included 4 WOT top speed runs and multiple runs from 0-60 or so wide open. I also ran 70+ mph at nearly wide open throttle for an hour straight the other day. I could have gotten even better mileage.
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
#228 |
Let’s see if I can get these luggage pics to post properly instead of sideways. The first is my current luggage assortment including the book bag. The next is leaving my house, and then the rest are arriving at the girlfriend’s house an hour away.
I love these Harper Chase bags and think I’ll buy the matching saddlebags so I can retire the book bag. Sigh... I see one made it right side up. Small victory I guess.
#229 |
Even though the pics are upside down the bags still look great!
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-05-2020 at 11:00 AM. |
#230 | |
I had to retighten my new chain tonight. I noticed it was sagging down and nearly resting on the top of the swing arm on my ride home from work. I hope it’s all stretched out now and won’t continue to require adjustment.
#231 | |
#232 | |
#233 | |
#234 |
The aftermarket sprocket is thicker than the stock one which is why the steel ring and the snap ring won’t fit so I might just sand both sides of the new sprocket down equally until it’s the same thickness as the original. I think that would be easiest for me with the tools I have and I’ll use my digital calipers to make sure it’s accurate.
#235 | |
#236 |
Tell me about it. I already want an Orion RXB250L and then that new cruiser Venom is putting out looks sweet as well. I need to get my Chinese bike buying desires under control.
I do love the idea of buying bikes with this CB engine though so I’m familiar with the mods and working on it. I have my eye on those new offerings with EFI, 6 speed, and larger displacement next year too. I think I basically just need to marry a rich woman so I can have about 10 bikes.
#237 |
Tonight’s project included removing the aftermarket sprocket and narrowing the area where the factory steel retainer ring goes in order to install the snap ring over top of it. The aftermarket sprocket is wider than factory so the snap ring doesn’t fit into the groove with the steel ring installed, but the snap ring digs into the aluminum sprocket without the steel ring and would have eventually worn through it.
I removed the sprocket with the intention of just sanding the whole face of it down but I got no where fast doing that. I ended up taking an angle grinder with a 60 grit flap disc on it and narrowing just the inner portion of the sprocket where that steel ring rides. I took off a little bit at a time and test fit it until I took off just enough. The stock sprocket is .28” wide, the aftermarket one is .32” wide, and the steel ring is .08” wide, but the stock sprocket also has recessed portions where it bolts to the wheel so I had to take the sprocket all the way down to about .24” thick for the steel ring to fit. I’m visiting two cities this weekend and running about 230 miles round trip so I also topped off the battery’s charge and added the EZ tire beads to each tire which balance them as you ride.
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. Last edited by Chrisguga; 05-08-2020 at 07:24 AM. |
#238 |
Looks like that did the trick.
![]() I haven't used the tire beads on this bike yet. The tires seem to be well balanced. I don't know how your tires are holding up. I was looking at my rear tire last night and with only a little over 1400 miles the center groove is just about gone. The front still looks like new. I think i'm going to order another rear tire and maybe go just a little wider. 150/60-17 instead of the 140/60-17.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-08-2020 at 08:26 AM. |
#239 | |
My rear tire’s center groove is also almost worn out, but it has plenty of tread left on the sides so I may try to get another 500 or so miles out of it. I tires didn’t seem out of balance, but if I try to start pushing the bike to greater speeds with the new mods, I figured ensuring they were balanced at speed for $11 or whatever the beads cost was cheap insurance.
#240 | |
