Some update.
I did ride over 200 km with it. (130 miles)
The battery is dead, but whatever, the kickstart works for now. The ignition part sometimes pushes down or IDK, the key stuck in it. Not a big issue, but kinda annoying when it happens.
The Kickstarter is ok, however, under 50 F, it gets difficult to start the moped. When It's over 60 F, it starts without any issues. When it's 50 F or under, It gets tricky, I have to mess around with it, pulling the throttle to max + break and it usually starts then after a few tries. I did ride in 32 F too, it works, but it's way better if the weather is warm. I guess it's just not made for freezing cold temperatures.
Anyway, so far, 130 miles in it with the new carburetor and it works alright. Planning to put way more in it, as the spring is here.
