04-24-2020, 06:35 AM | #16 | |
But you get the gist - more coils and bigger and or wider equals more bigger number etc. |
04-24-2020, 06:37 AM | #17 |
The TT250 claims a 300 watt alternator. Do all of the counterbalanced Zhongshens have that? Looking at my Brozz, it has a rather large alternator bump. Just wondering.
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami |
04-24-2020, 12:08 PM | #18 |
No CSC specifically requested Zongshen to put in the biggest stator available (300W) for all of their models TT, RX3, RX4, SG ect. Zongshen like most Chinese companies will try to keep production cost as low as possible and use as small of stators as they can get away with. The exception is on their police models.
Id like to add that a clamp on meter to measure current is flawed. Cheap clamp on meters can only measure AC current at 60Hz. A motorcycle almost never has 60Hz frequency - only at a specific RPM. More expensive clamp on meters can accurately measure AC current at various frequencies. Only the most expensive clamp on meters are able to measure DC current found in most motorcycles. Measuring AC current and AC voltage at the stator isn't much use when you have high losses converting it to usable DC.
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
04-24-2020, 10:45 PM | #19 | |
CB and CG seem to have around 5-6 options on stator output claims etc and what I said is correct re diameter and width. CB and CG do not seem to share the same stator tho.... |
04-24-2020, 10:46 PM | #20 |
Study the pic of the stator or remove the cover count the coils, diameter and width - that tells all etc
04-25-2020, 09:57 AM | #21 |
The point I get here is that the weak nature of the charging systems and these small batteries dictate a battery tender is key to maintaining your battery in the best state possible prior to use. If you can't use a cord, I saw this solar charger for around $20.00 bucks and they make versions that go from 1.5w up to 8W.
https://www.amazon.com/SUNAPEX-maint...xpY2s9dHJ1ZQ== |
betraying light, brozz 250, electrical, generator, stator |
