04-18-2020, 11:19 PM | #1 |
(Thicker style) Fork brace
So I had a read of this post after reading Dan's trick and tips.
http://www.chinariders.net/showthread.php?t=19349 I ordered my brace back in april/may last year and I am now getting to put the bike together. I just reread the link and just saw in Nov that someone tried to use the same brace and it was too thick. I tried to mount it and it didnt fit between the wide part of the forks. Just wondering if anyone else on the forum had tried to use this brace, with success. This is the brace amazon.com/exec/obidos/ASIN/B07H1DCFL7/ref=nosim/refuge0d-20
Toys include Audi B7, running Stage 2+, S4 Brakes. My VW Vanagon is running 2.5l VVT Subaru engine, 18" AMG wheels, Porsche 944 Steering Wheel, W eekender interior. 1989 VW Vanagon Bluestar one of 2500, 1986 Honda Shadow, 2000 Suzuki Intruder, 1988 Kawasaki Voyager XII, 1976 Mercury Capri II, a bunch of Trailers including a shortened Vanagon for camping, a Sequoia and the latest addition a 2019 Hawk 250. (But dont tell the wife! ) (Latest latest addition a 1995 fwd Subaru SVX) Last edited by nij_tp; 04-21-2020 at 05:44 PM. |
04-19-2020, 11:46 AM | #2 |
I have the same brace. I mashed it together until it fit. Takes a little effort to keep it symmetrical but if I can do it anyone can.
It makes a nice difference in the front end feel of the bike. |
04-19-2020, 02:05 PM | #3 | |
thanks, Alex
04-19-2020, 02:35 PM | #4 |
I found this one but the one I got from ebay I cannot find. It was only $29. I think either of these will work with minor modification. Both may have to be bent a little to fit and of course drilled.
https://www.ebay.com/itm/SLOTTED-RAW...QAAOSwnDZUJz4C https://www.aliexpress.com/item/3292...archweb201603_ |
04-19-2020, 03:36 PM | #5 | |
Regards
Toys include Audi B7, running Stage 2+, S4 Brakes. My VW Vanagon is running 2.5l VVT Subaru engine, 18" AMG wheels, Porsche 944 Steering Wheel, W eekender interior. 1989 VW Vanagon Bluestar one of 2500, 1986 Honda Shadow, 2000 Suzuki Intruder, 1988 Kawasaki Voyager XII, 1976 Mercury Capri II, a bunch of Trailers including a shortened Vanagon for camping, a Sequoia and the latest addition a 2019 Hawk 250. (But dont tell the wife! ) (Latest latest addition a 1995 fwd Subaru SVX) |
04-19-2020, 04:07 PM | #6 | |
https://www.amazon.com/exec/obidos/A...im/refuge0d-20
04-19-2020, 04:56 PM | #7 |
None of them fit perfectly. They are designed for a Harley and thus require modification. I had to "pinch" mine a little to get it to fit
04-19-2020, 05:15 PM | #8 | |
04-20-2020, 08:13 AM | #9 |
This is the one we all been installing. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Like Megadan stated i also had to pinch it in a little to work.
04-20-2020, 11:28 AM | #10 | |
04-20-2020, 11:45 AM | #11 |
Yes, that's been the case. I lucked out and bought one when they became available. Just keep checking and it will pop up available again, That's what i did.
04-20-2020, 04:46 PM | #12 |
Cool thanks, will continue to look. I will try and pinch the one I have but it does look like it is going to put some real outward pressure on the forks. As you can see its not even that close, but Roundhouse says he made it work, so Ill give it a go.
04-20-2020, 05:05 PM | #13 | |
04-21-2020, 05:39 PM | #14 |
So once brain was engaged..... Reshaped using a vice and some thread and bolts.
When you squeeze with a vice the open ends want to fold in together so needing a way to keep them from doing that i grabbed some threaded rod, fender washers and nuts. In case anyone else has a blank mind moment like I did :-) Will post fitted pics soon
04-21-2020, 09:35 PM | #15 |
Smart. I used a piece of 2x6 I cut to the desired length. The bolts may be a better idea.
