#271 |
It is and today I’ll have it to check on a wheel to be sure
It’s going to Moscow |
#272 |
How’s the parts needs?
#274 |
I do. Estimated price?
#275 |
Is that parts kit specific to the RX3/NC250 or is a generic kit?
#276 | |
Not chassis I will look into pricing more soon, this kit is a little high and I may make the kit wityh cooperation with my NC250 wholesaler |
#277 |
So I bought a kit just to see etc.
Decent and a vast number of specialty small parts that may not be easily or able to buy at the local hardware store etc. It would be a 1Kg package and $30. "NC250 engine repair kit collects and trims 61 specifications and 136 parts, all of which are derived from Zongshen's after-sales system. The quality is guaranteed to protect your daily maintenance." in some way regardless what in it or not in it there may always be too many or not enough small parts. Maybe the sprocket bolt should be included and all small copper washers etc. Anyway here's what I know now. Here's the text from the photo translated and mutilated: Guide the installation of the standard dan 06X 1 small fly lock lock nut 1 machine can be chastised | 2 s2 and a half two innings of the world's draw more , 2 , 9B896-86 to turn K8 , high-combination battalion fixed block map to Xuan piston pin card And the . . . 65 . . . Non-standard outlets on head-out water pipe bezels . . . 1 . . . Non-standard bezel camshaft bezel 1) 1 station in the box bearing lift plant (2) go (1) 1 . . . Double-linked tooth-to-friction) hetero-shaped cushion chart . . . 1 . . . Ten keys (4x4x13) s balance shaft driven tooth assembly king key . . . 2 . . . 2nd . . . 2 . . . Say a rotor to assemble a semi-circular tin . . . 2 . . . Feed-Chi-Chi-Chi-Chi-Chi Twisted force elastic sincere pressure re-human twist (28) 1 Sealing sleeve Grip sealant sleeve . . . 1 . . . Alien sealing group valve cover seal ring s2 dead body crankshaft oil channel positioning pin 0-type Lishizhuang inner princess ambiguous 0 Nenga clutch cover small Zhukong bolt 0-shaped ring (17.5x1.8) s/ oil-barnet cover 0-type car (coarse filtration) | 2 . . . Sub-axis output axis also 0-type diagram . . . 2 . . . Presentand and (person 5X3.55) touch motor envious large view hole bolt type 0 type coupe . . . 2 . . . 20x20 Geogou each of the open country (fine filtration) Under the whole committee multi-industry release people . . . -Ber 2 sawoor II from Spicy Bamboo 5 (TD 2 Danshi IV ) 2 full-body bouncing from fc full leather book (916.5X2X 9029) , qing oil as from the low 1 24 2x2.5X 32) , timing active tooth lock lock nut flat pad map non-standard push washer small fly lock Tight nut thrust washer non-standard push heat (2) werewolf (16.5X2X27) balance shaft from the moving tooth lock lock disc pad plot double teeth small) assembly pad s1 ignition trigger head fixing screw The bolt . . . 2 . . . Magnetic motor wire-connected bolt a cover per5s Goodness 5X26 ssie-pan bolt machine strip fengguan board bee inspection one and oem chapter general NSX18 . . . 3 sheets of the top 40 pregnancy ( 1 . . . 6B70. 1 Bolt M6x10 Four-wheel shaft driven wheel fixing bolts 2 6B70. 1 bolt M6x35 s five-star tooth fixed bolt double-toothed small) turn-down screw transfer ear 1 bolt M6x 50 (stainless steel) s double-toothed "mo-control) fixed bolt 0 SB819. 2 Screw M6X20 s/ display fixing bolts 1 Post-Class and . . . ee (1) 6B16674 small plate twilight NM6X16 tip plus two-spoke man village, (new) (2) Wang Qingguo II and 0 6GB1674 small plate bolt M6 x 20 water-based station two plus man ES (1) Di (1 s tree ginghic gas head-wood body) Connection bolt (1) 6GB16674 small plate bolt M6X 25 vivid sub-national light-setting "2) cover fixing s2 6B16674 small plate bolt N6 x 30 Youhead EEC (9) 6B16674 small plate bolt N6x 35 water-poor national testing long model (3) Head Langu head 24 Dingxu machine all 7 station central village MX 6 was born to make a semi-chi stud bolt long - Although No . . . two s. one fo |
#278 |
I'd be interested in that kit or something similar, let me know if you plan on making it available and total cost to NY USA
Thanks, Ken |
#279 | |
#280 |
Here’s the tallish screen in the land
You can see the stock size behind it in black Shipping is crazy tho The blue is only protective film, material made in Japan it says Last edited by NzBrakelathes; 08-05-2019 at 06:41 AM. |
#281 |
Heading to LAX 30th Oct 2019, Vegas from about 1-8th Pheonix around 8-10th Nov and between that till 25th Nov I have FREETIME maybe go east towards Texas? more north? more east? or..........
#282 |
Tail light assembly
Greetings Brakelathes
I need a tail light assembly please. Half of the bulbs/ led’s have stopped and after stripping the rear end I’ve discovered its a sealed unit. My bike is a 2015 RX3 with the 17 front wheel so I’m pretty sure it’s the earliest model. Very happy to pay in NZ$ if that’s is still an option. Thank you 🙏 |
#283 | |
Send an email I’ll price it for you |
#284 |
Awesome
I’ve attached a picture
Thanks. |
#285 |
RX3 Tail light to New Zealand.
The tail light arrived today, only two weeks since I was able to order it through NzBrakelathes. It was really carefully packed with miles of bubble wrap and is pristine.
Thanks so much, I have a brand new replacement light at the cost of the shipping from CSC. Highly recommended, Thanks again ![]() |
