Old 09-18-2019, 08:32 PM   #16
Whisky   Whisky is offline
Whisky's Avatar
They are from a 2016 and all the yrs are the same.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 09-19-2019, 10:36 AM   #17
cbrfxr67   cbrfxr67 is offline
cbrfxr67's Avatar
Yesterday I'd asked a seller on Ebay if he'd mic a 2018 set and he replied with 39.5 and 41mm.?
No worries though. I think I have some 2014's lined up.
Going to be great to get rid of those turd shocks for good.
BD125-15
Old 09-19-2019, 06:47 PM   #18
Whisky's Avatar
So the 2018 are smaller, the ohlins kit is for all yrs, does not give u a choice to order for certain yrs.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2019, 02:47 AM   #19
Whisky's Avatar
Did some asking around and someone said the 2014& 2015 are the same and 2016-2019 are the same but they said they have 2 different part# but ohlins has 1 kit for all yrs so if that's the case then mine must be from a 2015.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2019, 10:32 AM   #20
cbrfxr67's Avatar
Found some 14's for $250 + $50 shipping. Tried for lower but meh, I need them sooner than later. Got some steering bearings to do while I'm at it and new tires to put on also. Can't wait.
BD125-15
Old 09-20-2019, 05:28 PM   #21
Whisky's Avatar
Where did u get the steering bearings at? That's the one bearing I haven't replaced.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-24-2019, 09:58 AM   #22
cbrfxr67's Avatar
got my forks in and I ordered some Grom bearings hoping for the best. If they don't fit then I'll take measurements and figure out what I need.
BD125-15
Old 09-26-2019, 05:55 PM   #23
Whisky's Avatar
Post pictures when done, I like seeing how others have made there bikes unique.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-19-2019, 06:05 PM   #24
ikeus685   ikeus685 is offline
Send a message via Yahoo to ikeus685
Originally Posted by Whisky View Post
Yeah there not cheap that's forsure, I paid 275. which I guess isn't to bad, Ive heard some paid less and some more but they are a nice upgrade and parts are available to improve even more. There again not cheap though.
I have consider this and have also looked at the quality suspension builders.
Also tried looking for an match with progressive suspension but; That is a complicated website to navigate through.
Old 11-25-2019, 11:19 AM   #25
wlfpck   wlfpck is offline
No idea which you got... but...that is correct. On the Grom, the 1st gen and the 2nd gen have different fork internals.
The Nd4SPH (however you spell it) fork mod works on the 1st gen but not on the 2nd gen forks.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 11-26-2019, 02:21 AM   #26
Whisky's Avatar
I looked for the Nd4SPH mod but was unable to locate anyone that had it or where to get it so I just went with the Race Tech springs .065. I have not installed yet but will be an improvement I'm sure.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-26-2019, 09:31 AM   #27
The mod is basically some parts from a hardware store. The top of the idk what it is called sits inside the fork cap. What the mod is, is that it creates a spacer so that it adds more preload.
https://www.hondagrom.net/forums/49-...ds-better.html
This works only on the 1st gen Grom forks.
For the second gen Grom forks...
https://www.hondagrom.net/forums/7-g...orks-free.html
In the two links, you can see how they're different. I have no idea how the Grom Clone forks are (I never opened mine up).
Either way... I think swapping to the Grom forks like you did is the best option since it opens you up to the aftermarket fork internals.
2020 Honda Grom
Old 11-26-2019, 05:35 PM   #28
Gen 2 Grom preload on Boom Vader forks
Take down was a bit different than expected. I found you need to remove forks from the triple clamps to enable one to grab ahold of the caps to remove.
Shush319 On the Honda Grom site 8/13/17. Explains his dilemma and what he found.
I have a BD125/10 and appears to be near identical to the Gen 2 and so can do his mod to gain some preload.
You see 1 shock in the normal position and the other has the approx. .5" threaded towards the cap. Hope this does it. I can't find my measuring cup.
Anny idea how much in each fork is needed?
Old 11-27-2019, 05:11 AM   #29
Whisky's Avatar
wlfpck Thanks for that write up, I was aware that it did consist of some hardware items but did not have a list to go by. Next yr when I get around to improving the forks I might try this along with new fork oil and the race Tech springs. Thanks again.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-27-2019, 08:40 AM   #30
No problem!
This is the part list that is for the 1st gen Grom to do that ND4sph mod.
2x - 59363-F - 1in Spacer (5/16ID - .469in OD - 1in Long)
4x - 3815-F - Neoprene washer (7/16ID - 1in OD)
2x - 43110-N - M8x50 1.25 pitch bolt
2x - 43893-E - Small M8 Washer
The part numbers are from Hillman.
2020 Honda Grom
Search this Thread:
Advanced Search
Display Modes
