RX3 recommendations June 2019?
Hi, I'm joining the RX3 family next week, picking up a used one. I've been reading everything I can, and I have to say this forum is simply outstanding. But so much of the interesting content was put up in maybe 2015 or 2016, so I'm just checking on a few things so see if anything's changed or these things are still recommended now?
1. Oil change and oil filter. The bike is a 2018, with under 500 miles. I'm thinking of changing the oil before riding it much. Is there any cross-compatible oil filter available in the US, or a HiFlo model or anything? 2. Sprockets. At one point Spud had highly endorsed a 13T/46T combination. Is that still the way to go? Does it impair highway speed much? Intended use is lots of trails and highway to/from those trails. 3. Big bore kit. Read a few glowing reviews on the 283cc big bore kit, and I can see adding that after the warranty runs out. But there was also a 300cc kit, and I don't think I've seen any reviews on that. Has the 283cc proven reliable? Has the 300cc proven reliable? Would you go for one now? 4. SpeedoDRD. I have one on my Benelli and love it, and plan to get one for the RX3. The review from 2015 says that none of the other DRD models fit the RX3. I found that the H1 model fit my Benelli, even though there's no good reason why it should, I guess. Here we are in 2019 -- is there a confirmed SpeedoDRD that fits the RX3? Or do we still have to splice wires? 5. Overheating. I think it was Spud or someone else said they ran into overheating with the 283cc kit. I ride in HOT climates a lot. Has overheating been an issue? Is it limited to the big-bore kit bikes? And has something arisen in the last few years that resolves it? Thank you very much for any assistance you can offer! |
Welcome aboard and congratulations on the purchase. The RX3 is a really fun bike to ride. In regards to the oil filter... I switched to the metal reusable one and loved it. In the long run it'll save you money ....IMO. I bought mine on AliExpress.
http://redirect.viglink.com/?format=...1-bebc73878154
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
1. Oil is cheap. I'd change it unless you are convinced the PO already did so. The filters are not compatible with anything I have found locally. I bought a bunch from CSC.
2. Before you go to changing sprockets you should ride the bike and see if the stock setup meets your needs. The countershaft sprocket is torqued down quite a bit and I found it to be a real PITA to remove. The rear sprocket is much easier. If you change sprockets you may as well install a good aftermarket chain. The OEM chain is a known cost cutting item. The engine does not generate much oomph until it hits about 4K rpm. You can gear the bike so that 4-7K range is anywhere you want it. You will trade between torque at low speed or at high speed, your choice. You cannot have both. 3. Big bore kit. Once again, ride the bike stock. I find the stock setup to be OK. 4. I use my GPS to calculate speed. My front wheel is a 19" (as found on the 2018 bikes?) and the speedo is fairly close to reality. Of course that changes as the tire wears. 5. Overheating...I'm in coastal Virginia where it gets too darn hot in the summer. Even with stop and go traffic I have never had a problem with overheating. Yes, the fan will come on and the hot air blowing back is noteworthy but the truth is I wimp out long before the bike overheats. The dual radiators are quite good at shedding heat. FWIW, I actually found that my bike runs too cool most of the time so I installed a higher temp thermostat. |
Hi Gaijin.
Riding a Benelli indicates you are an experienced rider, and with that comes knowing that each machine has it's pros, cons, and limitations. I've not gone to a big bore simply because I've learned over the decades that trying to make a bike something that it is not, just consumes money that could be more wisely invested in a more suitable bike. The RX3 is a quite capable 250. Change sprockets, change bars & seat and such to suit your comfort, but don't try to make it a budget KLR or DR 650. If there is an alternate paper filter, I am not aware of it. As DPL096 has said, some have gone over to a washable metal filter. I have chosen to continue to order filters in the six-pack from CSC primarily because I believe in supporting the company (and the owner) that invested the money and effort to get the bike(s) emissions certified, upload the tutorials, and keep parts in stock (far better than my local Honda dealers) for us. The only overheating incidents I recall were from low coolant levels. The whole system of 2 radiators, hoses and engine only take about 1 liter of fluid, so keeping it full is essential. As Peter said, they tend to run cool and a higher temp 'stat is a good idea to keep the engine happy, boil off water from the oil, and make the fuel injection run optimum. Note to self: I really should do Peter's upgrade. Hope this helps. Happy riding.
Horse holder at Madame Orr's House. |
#5 | ||||
Thanks for the responses!
As for "riding the bike first", I totally understand, and the trip home alone is going to be 1,335 miles, so yes I'll know the bike pretty well by then. I agree about changing the chain with the sprockets, most definitely. Quote:
Mainly I'm going to be ordering oil filters in bulk from CSC, and if I put the sprockets on there it gets me close to the $100 for free shipping, so I'm basically asking "why not"? Quote:
Glad to hear the report on overheating. I lived in coastal NC and the summers were oppressively hot, and I'm in Texas now which is even hotter, but it's more of a humidity heat than it is truly high temperatures (like 117+ in Vegas/Arizona, vs. about 102 here) so maybe it's not anything to worry about. |
1. No other options, and the metal ones aren't really a filter so I would strongly recommend against it. They're just a screen to catch chunks, which the bike already also has. Order a kit from Tako here on the forum and you'll be good.
2. I went a tooth down on the front and love it. Highly recommend it. 4. I installed the universal one, works great, easy install. |
And that is precisely what makes Steve Seidner and CSC a class act.
#8 | |||||
That said... two hundred bucks for the big bore kit... it calls to me... ![]() Quote:
#9 | ||||
#10 | |
CSC isn’t always good or bad but you have choices etc |
#11 | |
Yeah, that's your guy. The filter kit has everything you need and more. Reliable shipping and service, good deal.
#13 |
The SpeedoDRD works you have to cut the plug and solder the wires it was about 10% with my kenda's. I like to know how fast or slow the mighty Zong is really going. Ride it first before you change sprockets it did not take me long to find out my zong was geared to high for me just going to 13th front sprocket was the single best thing i did for my to fast blue
Peace and Zong Life
#14 |
I have no experience with the RX3 (yet) but I do have quite a bit of experience with big bore kits, and my advice is don't. The bottom end and transmission were not designed for more power. More power equals more stress on engine parts. In every case where I have installed a big bore kit, it has noticeably shortened the life of the engine, decreased reliability, and in some cases broken the engine. I gave up. My feeling now is if you need more power, get a bigger bike where the whole engine and transmission is designed to handle the power it makes.
#15 | |
The big bore kit on the RX3 does nothing for the top end. The EFI and ECM really limit the bike. What it does do is wake up the mid-range and most importantly, it makes between 3500-5000 RPM's usable. These bikes are anemic below 5000 rpm's in stock form. I agree with you regarding really pushing the power out of a motor, especially since a modded motor is usually ridden harder but in this particular case, I really don't think the big bore kit even stresses it past its original design HP. I wish it would! ;-)
