#121 | |
That's how HD makes their money, replacing parts that fall off. I've picked up enough HD parts along the highways to build a mongrel bike. ![]() |
#128 |
Wow...those are some nice farkles!!
#130 |
This bike is electric start only? No kick start? It has disc brake front and drum break rear? And the absolute maximum top speed is 80ish mph?
#131 | |
The DF does not have a kick starter. |
#132 |
I'm referring to DF250RTG/Venom Sportster Chopper 250cc (was told same bike). What is DF and RE exactly? I'm guessing shortening of model names.
#133 |
The DF250RTG does not have a kick starter. It is a carb bike so is easy to push start if needed.
#134 |
Since it uses the same engine as all the Dongfang full-size bikes, you should be able to add one if you needed to? But, as you pointed out you don't necessarily need one.
#135 |
I see. Off-topic question, does any kickstart kit work. Is there a specific one I have to buy. Can you recommend a kickstart kit for the DF250RTG?
