Old 02-19-2019, 05:30 PM   #5
Working_ZS   Working_ZS is offline
Originally Posted by woodlandsprite View Post
Hello hello everyone....
Question for you all - has anyone adjusted the position of the rear brake pedal? Perhaps drop it a bit from it's stock position?
Yes, it was one of the first adjustments that I made to the bike.
Look directly below the rear master cylinder and you will see a rubber boot covering the adjustable linkage between the master cylinder and the foot pedal. To adjust, peel back the boot from the pedal end and loosen the locknut. Then turn the link rod to lower or raise the pedal height. I have mine set quite low, so that I have to really try to engage it. It helps to avoid rear brake lockups when practicing emergency stops, since the RX3 has a very good rear brake.
Search this Thread:
Advanced Search
Display Modes
