01-20-2019, 11:25 PM | #1 |
Hawk Digital Speedometer/Cluster
Hi all,
I've sourced some digital plug and play (nearly) speedometers for the Hawk. I was on a waiting list for the speedo motocheez has on his website (hawkclusters@gmail.com) for about a month. I know it's the middle of winter, but I wanted a project! Installation was simple: unplug and remove the old cluster and speed sensor. Mount the new speedo and speed sensor (sensor will fit stock sensor perfectly-no need to mount magnets); plug in the digital speed sensor, plug into the stock wiring (this will give you everything you currently have available on the stock cluster). Then run the wires for the gear indicators and RPM sensor to the wiring harness by the battery. These wires are all clearly marked. I've attached a picture of the cluster for reference. If you're interested in buying one, please let me know. $90, includes ground shipping to your door-lower 48 states. |
01-20-2019, 11:54 PM | #2 |
Whats different than ordering from Matt? Is his modular or something?
01-21-2019, 01:39 AM | #3 |
Another supplier! Getting busy with us 3 lol!
01-21-2019, 07:44 AM | #4 |
I haven't seen Matt's (aside from pictures). But he seems to have a hard time keeping them in stock, so I thought I would offer an alternative.
01-21-2019, 09:07 AM | #5 | |
replacing the mechanical unit
My TBR7 has the mechanical speedo assy ( looks like the older hawk unit ). does this kit have everything to convert mine over ? Thanks |
01-21-2019, 12:08 PM | #6 | |
That doesn't mean these will or will not be, but that is one thing I know for certain about the cluster that Matt offers. Other than that, Matt is a stand up guy that really stands behind what he sells. Not to say these other vendors now offering them are not, because I haven't personally bought from them, but that I know Matt is for certain.
01-22-2019, 01:16 AM | #8 |
pilot jets?
01-22-2019, 08:57 AM | #9 |
My hawk also had a mechanical hookup running from the speedo to the wheel. This unit comes with a replacement cable (photo attached). It's a perfect fit for the wheel and plugs into the back of the digital speedometer.
01-22-2019, 09:08 AM | #10 | |
That said, I agree, Matt is a stand-up guy. I ordered a cluster from him in early December and sent him $95 via paypal. Due to my inability to wait, I asked him for a refund and he obliged. I certainly would have understood if he didn't permit it. This is just another option for folks who want a simple install. I'm not mechanically inclined but was able to perform this swap-out. |
01-22-2019, 09:11 AM | #11 | |
Hawk 250 Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
01-22-2019, 09:34 AM | #12 | |
Is there one that’s accurate with a tachometer set up for the 2017 “Bashan 250 Storm Rocketa”, 19” front wheel ?
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
01-22-2019, 10:42 AM | #13 |
If you could find a digital speedo / tachometer for the Bashan bikes you would find a niche. I would buy one for my Bashan Blaze if I could find one.
01-22-2019, 07:02 PM | #14 |
All are possible as you enter in the centimeter of the tire circumference
01-22-2019, 07:05 PM | #15 |
Can be
